Results 1 to 17 of 17
Thread: Vn shutting off wen driving
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Exclamation Vn shutting off wen driving
    Hey all my 89 vn v6 wen im at a stop or almost stoped sometimes the engine just cuts out nd is hard 2 start it did it the other week thought it was the fuel pump good thing coz pump was stuffed but its still doin it nd im stumped it has only done it wile im in gear (its an auto) any ideas on what it could b.
    Any ideas is helpful
    Hangman's Avatar
    Hangman is online now Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    At a guess, Crank angle sensor. Check your fault codes.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Hangman's Avatar
    Jan 2010
    There's an echo in here
    vs commodore
    Oct 2009
    Tamworth NSW
    A faulty CAS wont always throw a fault code.Sometimes they do,sometimes they dont.Ive seen a few now that havent.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    Quote Originally Posted by Hangman View Post
    There's an echo in here [/
    Jan 2010
    Kool as guys would that also cause it 2 idle low wen in gear? Nd how would i check the fault codes. If its not the crank sensor wat else could it b?
    Jan 2010
    Iv also been reading stuff bout dfi or sumtin could some1 tell me wat it is nd wat it does would it b worth replacing? Cheers guys
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    a faulty dfi module normally results in either misfire or no starting
    what rpm do you call low? in drive stopped still foot on brake?
    yon
    yon is offline
    vn
    Mar 2006
    calis vn v8
    Jan 2008
    my vn v8 also cuts out. But only when i go around a right hand corner and when the G's come on..
    So basically have to be going hard around a right hand tight corner......
    The engine cuts out - instruments - everything, then when the G's come off it cuts in again.....
    First time it happened, well - i shat my self. Was slowly drifting to the kurb (no engine to drive me out of the corner) then the last second it cut in........
    Thinking electrical, something moves and rubs on the body......OR the oil sloshes to the left of the motor and sensor cuts the motor out ???? When it does happen, it happens fast and of course i have my eyes on the road - so have not notice what comes up on the instrument panel either....
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by ybl8te View Post
    Ive seen a very similar problem,it was happening for months,it would just cut out around certain corners,no one could find what was happening.We tracked it down to being the main + power wire that goes from the battery,to the bolt that goes into the bottom of the middle fusible link,the fusible links are located down in front of the fuse box in the engine bay.Just follow the wires from the positive battery terminal if you cant find it.Theres a little black plastic door that pulls open so you can access this bolt,the bolt has to be removed if you want to replace the middle fusible link,and what had happened was the battery was moving around slightly from side to side when cornering,which was moving this power wire,this movement eventually caused the join where the wire has the connector crimped to it, to pull out of the connector, but it was making bad contact for ages and stopping the car, before it finally broke completely.If yours is cutting out,check the battery for any sideways movement,if there is,see if it moves this wire,and check the crimped connection behind the little plastic door.
  15. #15
    calis vn v8
    Jan 2008
    Quote Originally Posted by Brett_jjj View Post
    Thanks - i will have a look, i am thinking this could be it, I do know my battery does move and will make a bracket for this, thou still will look at the connection.....then find a good right hand corner and get the LSD working again !
  16. #16
    Jan 2010
    Quote Originally Posted by db_notso View Post
    Yer in drive nd foot on brake rpm drops 2 bout 500 - 600
  17. #17
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    hijackers~! love that they know what cable causes that though screwed me for a while one day!~
    anyway thats not really excessively low idle is about 100 rpm off very close might be old motor okay
    if raising the idle is all you want to do turn the stop screw on the throttle lever at the throttle body
    (where your accelorator cable goes)
    but be aware if you turn it to far it can set codes and faults in the transmission
    it should idle at about 700rpm in gear on brake BUT cars are individuals sometimes and may be + or - like 80-100 rpm
    so im not sure of the spec but if you turn it up abit it may not stall as often...
    you could just need to increase your idle speed a bit
    but without seeing/hearing car and faults i would say that the two problems arent related.
    so cutting out likely to be crank angle sensor (common as you can see above)
    but with out checking codes you wont know if its something else as if say for e.g. air sensor dies and stops car would set code...
    where as the crank sensor is stand alone monitoed meaning unlesss its a weak signal rarther than a complete loss of signal
    (they just die no signal normally) the engine light is not likely to come on
    without having you chase your arse around
    i would personally:
    1.check codes if any stored (follow that code if stored)
    2. check wiring connector on crank angle sensor is plugged in and tight (and terminals clean inside the connector)
    3.check throttle body is clean from gunk etc, (especially around the butterfly of the throttle inside it)
    if none of these help i would personally be watching a data display of the motor while the fault is happening to narrow it down to a specific sensor dropping out
    or reading ridicously, for you that woulod mean getting a mech to look at it JUST to DIAGNOSE it for you
    that way if you CAN fit the part yourself youll save some dollars
  1. thermo fan not shutting down
    By SS Manual in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-02-2011, 03:50 PM
  2. VX engine just shutting down.
    By Craig151 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2010, 09:50 PM
  3. VX commodore engine shutting down.
    Last Post: 19-03-2010, 12:49 PM
  4. Help with Laptop Shutting down randomly
    By weedo_86 in forum The LAN Lounge
    Last Post: 22-05-2009, 10:11 AM
  5. VN SS shutting down
    By snapey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2008, 07:13 PM
