Results 1 to 3 of 3
Thread: checking engine oil and transmission oil level correctly....
    92 VP Series 2
    Jan 2009
    East Brisbane
    Default checking engine oil and transmission oil level correctly....
    hey so i have just been doing some checks on all the fluids and oils in my vp v6, but am not 100% sure the correct way to check engine and transmission oil. i went for a small drive to get the heat up to normal operating temperature, then with the car running at idle, i checked the engine oil, and it sat just below the maximum mark, then i checked the transmission oil and it was sitting just below the minimum mark. i then turned the car off and re-checked the oils and with the car turned off, the engine oil was a tad ABOVE the maximum mark, and the transmission oil sat just below the MAXIMUM mark. which readings do i believe? should i add a bit or drain a bit of engine oil? and should i add just a little bit or should i add alot of transmission oil? cheers for any feedback
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    check engine oil hot or cold with engine stopped
    when hot if level is correct may seem a few mm above full this is ok but a cm over the full mark is bad
    transmission fluid
    check with engine running and go through every gear manually for two seconds then leave it in park and check it should be be close to the maximum mark
    should be checked hot but when first changing fluid check cold drive it then recheck
    92 VP Series 2
    Jan 2009
    East Brisbane
    sweet thanks heaps mate ay, just what i needed legend
  1. Checking Trans fluid level?
    By Old Colts in Oz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2011, 06:43 PM
  2. 304 Not running correctly
    By HAZZA-VN in forum V8 Development and Modification
    Last Post: 28-01-2010, 07:08 PM
  3. VS Auto Transmission not changing correctly
    By SteveHow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 01:45 AM
  4. Auto Elec on Ecotec engine and Level 3 Clsuters
    By Full Spectrum in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2006, 06:31 PM
  5. Transmission oil level??
    By scorpio in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2006, 08:38 PM
