Results 1 to 16 of 16
Thread: Timing Setting LPG 5L
    Snitz92 is offline LPG Sucks.
    '99 Subaru WRX, '89 Nissan 300ZX V6TT Targa
    Apr 2009
    Ceduna
    Default Timing Setting LPG 5L
    Hi, my VQ Statesman has a 5 litre V8 with an APA gas system fitted in 2007. I am aware that on normal petrol setting it should 10 degrees advanced from TDC. Just wondering if anyone knows what the timing is on an LPG fitted car?
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    generally lpg is higher like 15 but im in no way sure of this fact!~
    no seriously only had to mess with one i just set it drove set it drove withan adaptor module thingy
    was a long time ago and i cant remeber what it ended up at
    Apr 2009
    Ceduna
    Ok mate well I will soon be getting the LPG removed and stuff like that - was just curious as to what needs to be adjusted with the engine timing. Incase the LPG specialists are a-holes and don't reset the motor back to normal for me, i can do it myself with timing light. :-D
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    Apr 2009
    Ceduna
    Yeah cheers man. i've done bits and pieces of timing and ignition with my old man who's a mechanic, so that's not an issue. Mainly just want to know what setting best suits this engine and gas system.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    yeah know what you mean i asked one of the old 20year guys today and he said set to +5
    i asked huh +5 on standard?
    he said yeah because the lpg is a higher octane rating and burns differently!
    he did also add it depends on the motors internal conditions and that hed start at 15 and see if missed etc then lower it to 12 if had misses?
    not exactly sure what he bases this on but he is experienced? i guess 2o years had to teach him something about vq lpg v8's timing?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Petrol has an advance curve right through the rev range and is therefore not the ideal timing for LPG. LPG needs the advance to stop at 2500 rpm then stay static from there. If you run dedicated LPG then the memcal needs tuning, but since you are getting rid of the LPG anyway your original question is quite pointless....as is this post.....
    Visit my Facebook page
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    lol anyways not an abba fan do you know what setting to suit both petrol and lpg on vq v8?
    has got me scratching my brain after what you said and the old guy at work!~
    Apr 2009
    Ceduna
    I ain't sure guys. I think I'll just bump it back to 10 degrees BTDC as it says in Workshop Manual and chuck the gas tank.. Mmm.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    well it only ignition timing set it drive it hear for pinging and then advance it and drive again when it starts to ping drop 5-8 degrees off timing and your done
    Apr 2009
    Ceduna
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The way I set timing on non EFI cars is to advance it until it pings, then back off a touch until it stops.
    You can safely go to 14 deg BTDC but you need to run 95 RON or better. Leave it at 10 if you intend to just baby it around.
    Apr 2009
    Ceduna
    Yeah that's understandable. Although it's an efi 5 litre which at it's current setting is running quite thirsty. I reckon i might just back it to 10 and from there decide a more precise setting later.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by db_notso View Post
    Some people retard the timing a bit to make it run better on LPG, but leaving it at the stock 10 deg is fine. For the best results load a dual map on the existing memcal, one for petrol, one for LPG that is switched when you switch from petrol to LPG.
  15. #15
    VP Executive 5L
    Mar 2011
    Default 304 V8 lpg ignition curve details
    Bit of an old thread but if anyone cares, I have this gas curve in my V8 VP. Also is the details of degrees vs rpm and manifold absolute pressure (MAP). As well, a petrol curve for comparison.
    Timing Setting LPG 5L-my-vp-v8-lpg-advance-curve.pngTiming Setting LPG 5L-my-vp-v8-spark-table.pngTiming Setting LPG 5L-stock-vp-v8-petrol-advance-curve.png
  16. #16
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    most gas fitters won't upload a dual curve pattern to these engines and leave it set a 10 degrees , sure the system is a APA ? apa is normally a brand of tank and not the system .
  1. setting timing on modified carby 202 black
    By zaczac in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2010, 08:23 PM
  2. 304 Setting timing
    By deanos70 in forum V8 Development and Modification
    Last Post: 28-12-2009, 11:26 AM
  3. timing belt/chain setting
    By CAL-FTW in forum V8 Development and Modification
    Last Post: 04-10-2009, 07:33 PM
  4. Timing belt to Timing gear's ?????
    By MMH84D in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 11:28 PM
  5. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
Tags for this Thread
