ask your mechanic next service. It may need re-tensioning or replacing. Depends on the engine.
when should the timing chain be replaced in a vp v6. mine has done 120 000 kms and i like to avoid unnessary problems caused by lack of maitainance so if it should have been changed by now pls let me know.
i had a problem with mine back when i had the vn, had 200000 though, but its a big and expensive job, i got rid of the car before i changed it, but yeah ask a mechainic
400000+ no change noise typical from tenion pully grease
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
lool ... thats the greatest avatar ive seen yet
Originally Posted by burnz
How the ****, aren't they supposed to be replaced every 100,000k?
I think that is for timing belts. Not for timing chains. Mine is giving me the shits. I am sick of hearing it. My motor has done 305,000 or so km.
Yours Kindly,
Jim
belt chain? why are some different?
I don't know what mine is...
by timing belt i think he means fan belt (serpetine belt)
Illegitimi Non Carborundum
commodores dont have timing belts, only chains except oldschool 202's they had steel hypoid gears. not sure on the alloytech though. timing chains arent a servicable item, you only replace it when its noisey. if its not broken dont fix it.
VN V6s use a timing chain, I think mostly of the overhead cam motors use an actual belt, like I know the VL engines use a belt.
Yours Kindly,
Jim
mines done 225000 kms, and not had it replaced, or even tightened.
