Results 1 to 3 of 3
Thread: installing extractors
    Ford Xe
    Dec 2006
    Default installing extractors
    hey guys not specific enough in other posts
    im trying to dismantle the drivers side manifold but having trouble. i know i have to take off the p/s rack but to undo the bolts im trying to take off the steel coolant pipe and cant undo the bolt from the back where engine crane thingy is
    how do i go about this the easiest way?
    cheers
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    Which bolt specifically? (pics would help)
    The Coolant hose has three (Rear through manifold, mid through manifold with dipstick, front into block under tensioner pulley assembly)
    The lifting point doesn't need to be removed if i remember correctly...
    Ford Xe
    Dec 2006
    well ive undone the 2 bolts that go to the manifold. and ehind the motor theres a 17mm bolt that holds the coolant pipe.. because the coolant pipe isnt coming off and i cant get to the manifold bolts. im stuck
  1. Installing extractors V8
    By BHAZA in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2010, 04:42 PM
  2. Installing Extractors to a VP V6
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2008, 05:41 PM
  3. installing extractors
    By vs-s-pak-ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2006, 06:39 PM
  4. Installing extractors/exaust (VT 3.8L)
    By upthetiggers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2006, 11:24 AM
  5. Installing Extractors
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2005, 11:02 AM
