Results 1 to 4 of 4
Thread: Fasteners
    VN CALAIS
    Sep 2006
    Default Fasteners
    Can anyone recommend an alternative to the factory trim clips which hold on the door cards. When I pulled them off to get at my windows some broke and the only option I have found so far are replacement items from Rare Spares that don't come cheap for what they are.
    Is there any cheaper alternative that is actually better?
    Also, when people are bolting power window regulators back in what size- as in length as well as height of both the nut and the head of the bolt- is best? I don't want to go too long and foul on the window or make the trim sit up further than it should.
    Thanks.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Try the wreckers or maybe a panel beaters, not sure of the power window stuff though.
    Best RPG ever
    Portunio is offline The Gaffa Tape Wizard
    VP S2 V6
    Feb 2006
    Melbourne, Victoria
    You want M8 thread bolts, roughly 16-20mm in length. From memory those are the ones we use. You can still get the correct rivets from Holden and many mechanics would recommend this rather than bolts as they reduce the risk of anything coming loose, however I've personally never had trouble with bolts - but a little loctitie never hurts.
    As for the clips, I'd personally just take a trip down to your local pick-a-part and grab a few there. Chances are you may find a door trim thats already been removed just floating around.
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    you can get trim clips from the wreckers, unless they've ripped of the door card itself? then don't try liquid nails.. lol
    and for the power window bolts, i'd recommend rivets (they don't have to be genuine, you CAN of course use any) but each to their own. Up to you.
    If you think you'll be needing to remove again soon, then maybe drilling out may not be your thing, go with bolts..
