Results 1 to 14 of 14
Thread: how to hard wire your thermo if fan not working
    vn wagon with nitros
    Aug 2010
    hobart
    Question how to hard wire your thermo if fan not working
    please delete thread
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    vs commodore
    Oct 2009
    Tamworth NSW
    Running the cooling fan constantly will load up the electrical system all the time, and will cause the engine to take ages to warm up and get to its operating temperature.An engine that runs cold all, or most of the time, will cause the engine to wear out a lot quicker than normal, and will also cause poor fuel economy.Its better to just fix the problem that has caused the cooling fan to fail in the first place.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    no relay is a bad idea running the power scorce from the ciggy lighter fuse bad idea
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Good for a quick fix though if you are out the middle of no where and your car is over heating and the thermos arent working.
    Pretty sure he doesnt mean for everyone to go out and do this if they dont have problems.
    Best RPG ever
    в∞ѕтεכ √&
    Jul 2008
    NZ
    quick fix for that is a loop of wire in the relay holder no wiring mods at all LOL
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by 2DIE View Post
    Yeah I agree about the quick fix in the middle of no where to get out of trouble,but if someone does have problems,its better to fix it properly than just bodging it.Each to their own though.I dont like doing bodgy things to my my car.I like to keep it reliable and in an original condition..
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    If this is your permanent way of fixing your over heating issue, I would have setup a relay in the engine bay, then run the relay switching wire into your cabin and installed a switch on your dash.
    That way driving around, then when you are stationary or driving slowly then switch on the thermo fans.
    There is no harm to the thermo fan running full time, as I used a VN V6 thermo fan and shroud for my speedway car and it used to go full time.
    End of the day you aren't looking at the real issue why the ECU isn't kicking the fans in when the temp gets above a certain temperature. I would be checking your coolant sensors, yes there are two in the V6s, one for gauge and one for ECU, I say the one for the ECU which I am pretty sure is at the front of the engine may be stuffed.
    As said if you are in the middle of the bush or somewhere, you could just wrap a wire around your positive battery terminal and run it straight to the positive of your fans, or find a switchable power wire too run power from.
    Yours Kindly,
    Jim
    varies
    Jul 2008
    gone
    hot tip, that ain't a quick fix.. and if you're carrying the stuff for this 'patch' around in your car, then you could easily troubleshoot and repair your existing curcuit or just utilize a relay from elswhere...
    Also, why is it most people ALWAYS decide to run EVERYTHING of their AUX line?
    anyways, if it's a quick fix your after, nothing beats ultra quick & dodgy, as Delco says:
    Quote Originally Posted by delcowizzid View Post
    vn wagon
    Nov 2010
    nsw
    Excellent
    I have just got this very problem.
    Now, it throws NO codes.
    Fan DOES work when in diagnostic mode.
    Relay tests fine.
    Fuses A-OK.
    Fan DOESN'T work under normal conditions, as I have overheated twice and NO fan.
    Q. If the coolant sensor is kaput, wouldn't the car run rich. eg. bad fuel economy??? Mine has excellent fuel economy. Runs rough occasionally, goes like a scalded cat (I nicknamed it Crankydore)
    Only overheats in slow going - busy car parks on a hot day etc.
    NO bubbles in header tank, nice clear coolant. Oil is good.
    Could it still be the coolant sensor or is the ECU stuffed????
    Looking foward to informative replies
    cheers
    Aug 2010
    hobart
    Aug 2010
    hobart
    also have put a relay in now and made a switch so fan not on all the time only use it when in city and that when it look likes it geting warm
    VP Exec
    Jun 2005
    There is a lot of info. in a "How To" on switching the fans manually which will be worth a look if posters in this thread are unaware that it exists.
    An ECM fault can cause incorrect fan switching.
    Feb 2004
    NSW, Australia
    Quote Originally Posted by bruggz351 View Post
    Excellent
    Relay tests fine.
    Fuses A-OK.
    cheers
    I am pretty sure that's a different sensor again regarding to fuel intake. There is a sensor at the very back of the engine block rear of manifold and one at the front above the water pump. Look at these two first.
    Yours Kindly,
    Jim
  1. Vp Thermo Fan Not Working
    By lucas23 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2010, 07:22 PM
  2. Thermo Fan Not working at all
    By VGUNIT in forum Electrical Wiring / Questions
    Last Post: 01-10-2009, 05:18 PM
  3. Thermo Fan not working
    By Gambit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2007, 11:09 PM
  4. thermo fan not working
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2006, 10:20 PM
  5. thermo fan not working
    By paul 11 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2005, 06:19 AM
