Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Brett_jjj
Thread: Vp Panhard bushes
    VP
    Sep 2010
    australia
    Default Vp Panhard bushes
    Hey Guys.
    so i has a wobby rear end. How hard is it to replace the panhard bushes. And how do i go about it
    vs commodore
    Oct 2009
    Tamworth NSW
    If you get nolothane type bushes, they come in two pieces so they just push in by hand.The old bush, if its original will sometimes need to be cut out with a knife.Ive ran into a few like this now that Ive had to cut out to replace them.Its not hard to do though.
    Portunio is offline The Gaffa Tape Wizard
    VP S2 V6
    Feb 2006
    Melbourne, Victoria
    Its fairly straightforward, jack up the rear of your car and place it on stands. Next, undo the retaining bolt at each end and pull or pry the panhard rod free from the vehicle. Next step is to press out the old bushes using a hydraulic press, alternativley you can press them out using a bench vice and a socket of the same diamater (or slightly smaller) as the bush. From here on the proceedure to fit new bushes is the reverse of removal. Remember to grease up the new bush before attempting to press it in.
    VP
    Sep 2010
    australia
    vs commodore
    Oct 2009
    Tamworth NSW
    I wouldnt bother mucking about pressing the old ones out,it takes all of 10 seconds to cut them out with a knife.And the nolothane type bushes come with a packet of grease.
    VP
    Sep 2010
    australia
    VP S2 V6
    Feb 2006
    Melbourne, Victoria
    The grease serves two purposes, firstly it makes pressing the bushes in a shitload easier. Secondly it stops the new bushes from creaking and squeaking as certain loads and forces act upon the suspension.
    VP Exec
    Jun 2005
    Dishwashing liquid/liquid soap is preferable to grease though as it will wash away after installation and not interfere with the way the bushes are meant to work. You can install them dry but it's a bit more difficult.
    Snap-on's Avatar
    Snap-on is offline Boilermongrelin
    82 VH, 99 VT Wags, 03 VY S
    Apr 2008
    Brisbane, Northside
    Just did mine the other week. I pressed the old ones out, but cutting them would work. I replaced them with single piece press in superpro bushes. Just greased them up with the grease provided, and with one good smack with the hammer, they fell in!
    VT Ballin'
    VP
    Sep 2010
    australia
    Well the bolts are being stubborn so i hit it with some wd-40 and ill attack it tomorrow moring
    VP Berlina
    Aug 2010
    vic
    You could always use a steal pipe as leverage, so long as your tools are strong enough, thats what I did.
    VS Executive Wagon
    Feb 2012
    Mornington Peninsula
    Im assuming this will all work for a VS Wagon too? just jack it up, undo the bolts, replace the bushes and reassemble....
    VS Executive Wagon
    Feb 2012
    few commodores
    Feb 2011
    victoria
    can also get 1 piece nolathane (super pro etc bout $20 from super cheap) once the old ones are out grease the new ones and even though fiddly to line up straight and hold, use a vice to push them in if you don't have access to a press, used this method quite a few times even though i have a press here i found this just as quick, i've always used the old crush tube (only one used on these) as long as it's in good condition and not rusted/pitted
  1. replacing panhard bushes
    By samvn87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2010, 01:28 PM
  2. how to change panhard bushes vs live axal
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2009, 07:05 PM
  3. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  4. Panhard Rod Bushes
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2006, 10:29 PM
  5. Panhard rod bushes in :)
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2006, 09:55 PM
