Results 1 to 5 of 5
Thread: VP odometer not turning
    VP Commodore S 5spd
    Jan 2011
    Eastern Australia
    Thumbs down VP odometer not turning
    hey everyone, how ya goin? i'm new to the forum, and had a little look around for an existing thread but i couldn't find one. Problem is that my VP's odometer is not functioning, and i wanted to see what you guys thought would be the most economical and/or simple way to fix this problem. whether to replace the entire cluster or even if that would fix my problem? cheers guys
    VN Wagon
    Feb 2005
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    you can buy the little gears on ebay for about $15. There's also info online about pulling the instr. cluster apart to get the job done. There is a way to get at them without taking the arms for speedo etc off their mounting pins. Good to avoid doing that if you can. Good luck with it if you haven't fixed already. Rob
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by VPS92 View Post
    A replacement cluster will often have the same issue with a broken cog. You can replace the cog without taking the needle off - just a little tricky getting one small screw into place. Test it clocks over k's smoothly before replacing in the cluster. Also make sure you have all the missing teeth from the cog out of the speedo - if 1 tooth remains it can jam up the speedo and smash up the new cog in a flash. (yes speaking from experience).
    and 3 Dangerous non ABS VN's
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    another easy fix... if you have access to a self serve wrecker, pull a cluster out of a wrecked VS or something. dismantle the odometer and pinch the assembly of internal gears. Smaller than the size of a 10c piece
    I found that the later VS's had nice strong plastic gears, where as the older ones were all brittle.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. Accessories turning on by itself after turning car off
    By Danny40 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 11:04 AM
  2. vr odometer
    By callum87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2009, 08:54 AM
  3. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  4. vx ss odometer
    By Sir VxSs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2008, 07:20 PM
  5. Odometer.
    By benjiaka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2008, 11:59 AM
Tags for this Thread
