Results 1 to 15 of 15
Thread: Engine mounts vn?
    3.8L S1 VN
    Stick Avalanche Champion!
    Jun 2009
    latrobe valley
    Default Engine mounts vn?
    hey guys, i need to replace my engine mounts, as the ones i have, have sagged.. so i found that there's hydraulic mounts, or regular mounts.. i understand the difference, one has fluid, one's solid.. but i was wondering if someone could clear up a few questions.. i read somewhere "hydraulic mounts came factory in this car" i dont think that was written about a vn, it was about a commodore, but not a vn, so my question, were hydraulic mounts standard in a vn? also, i've read somewhere that there is a fair decent price difference, so when i called supercheap, i was given a price of $155 (roughly) for the regular ones, or $165 (roughly) for the hydraulic ones, obviously i will go with the hydraulic ones as there is only a $10 difference, but is this correct? from what i've read they should be much more expensive then just $10 compared to the regulars.. so yeah, would somebody please just be able to give me a little detail on these hydraulic mounts compared to the normal mounts? (e.g how much better are they? do they come factory on VN's? i've read that they get rough after a while, someone said it could be the fluid leaking out any ideas on this?)
    Thanks alot guys!
    ve sv6
    Aug 2010
    i know vr onwards have hydrolic one and im pretty sure vn and vp do as well. the hydrolic one help soak up engine vibration. as for price are you talking a pair? if so i think thats about right.
    3.8L S1 VN
    Jun 2009
    latrobe valley
    yeah mate thanks alot! i was told about 155 a pair of non hydraulic, 165 a pair of hydraulic.. Does anyone know if either of the two are stronger? i'm happy to sacrifice comfort for strength if the regulars happen to be stronger, but if not, well the hydraulic it is!
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    solid ones are always going to be stronger. Problem with hydraulic filled ones is that the rubber perishes and the fluid leaks out then theyre stuffed. This will only happen faster if theyre allowed the be contamined by engine oil and the like which attack the rubber otherwise theyd probably last a lot longer
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Check out the TTT Performance sub forum on here. They've made up a new style of mount that should prove to be much stronger and durable than the standard mounts.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Umm I was under the impression the hyrdaulic ones were stronger then rubber. Hence why Holden used them. Holden being Holden wouldn't they have used rubber ones if they were cheaper?
    Yours Kindly,
    Jim
    Vn berlina, Vn calais
    Jan 2011
    I replaced my vn's with soild rubber from Sprints they were $49 each and trans mount is worth doing as well at $25
    3.8L S1 VN
    Jun 2009
    latrobe valley
    thanks for all the help guys, one more question.. i've just got the engine mounts, i've baught a transmission mount, im clear on how to do the trans mount, but as for the passanger side engine mount i'm a little concerned, i read something about two bolts letting the gas out of the air con compressor, not keen... i had a bit of a gander, i noticed the 3 or 4 (not 100% sure on if i could see a fourth or not, but i think so) bolts going through the compressor holding the bracket on, so i'm assuming i just undo them four bolts connecting the compressor to the bracket and then i can make me way to the bolts holding the mount on after lifting the engine a little? any tips much appreciated guys! i have a feeling this will be a hell of a job :/ lol
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    four bolts hold the pump top the bracket then it can be moved to the side then you need to support the motor on a jack and remove the mounts attached to the brackets and install is a reversal
    VN Calais With All The Factory Fruit I Need!
    3.8L S1 VN
    Jun 2009
    latrobe valley
    yeah, thanks alot mate, however i've already done it :P i just finished, i did both engine mounts, and the trans mount. buuuut now i've encountered a serious problem, when i went to move my car from the driveway, she wouldn't start eh.. it was almost as if my battery was nearly dead.. but at different points it would try kicking over.. like it did nothing, but i'd move the key slightly, and then it'd very weakly try to turn over.. but it was getting nowhere, i didnt try many times, nor for too long each time, but now it won't start, at all, AND the last time i tried to start it (you'll understand why i didnt try again..) smoke poured out from the bottom left of the windscreen, i think i may start a new thread asking about this problem.. it has to be something electrical in my opinion, why else would there be smoke when the car wont start..? but anyway, as pissed off as i am, i am very happy that i saved $400 by changing the engine, and transmission mounts myself. All the help was much appreciated, thanks alot guys!
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    When mine were done the solenoid cap came loose from the starter motor, to start it had to push the cap on the end in. Worth a try. Got super annoying in the end needing 2 people to start the car so i got a new starter motor, genuine bosch (one of the last made).
    D22 St-r Navara
    Dec 2010
    perth
    VN Executive
    Dec 2006
    Queensland
    I got sick of breaking mounts every few months and made some using a 2" x 4" nylothane bush as the center. Bolt thru bracket to bottom mount. Steel casing for the bush to go to the top mount. Almost solid, but with enough give to take the vibrations out
    D22 St-r Navara
    Dec 2010
    perth
    Quote Originally Posted by vaxx View Post
    bet your neighbours got sick of you revving your guts out every where you went also
  15. #15
    VN Executive
    Dec 2006
    Queensland
    No neighbors here Great thing about the bush.
    I'm only running a 2 1/2" hotdog after the cat with a 3" straight pipe under the diff .
    Surprisingly not that loud. 87 db at 5000 rpm
    Got sick of the engine jumping around under brakes and acceleration.
    Disturbing weight transfer in corners.
  1. VS engine mounts
    By Mattrob in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2011, 12:50 AM
  2. VT Engine Mounts
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2011, 05:45 PM
  3. vt v6 engine mounts
    By dagsy in forum V6 Development And Modification
    Last Post: 04-10-2010, 04:08 AM
  4. Engine MountS!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2007, 02:43 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
