Results 1 to 7 of 7
Thread: vp sedan front end suspension...
    vp sedan
    Jun 2008
    Default vp sedan front end suspension...
    recently i off-roaded into the kerb! did the tie rod on the rack and the strut....but after putting in the new strut the wheel is still too far back! is this due to the lower control arm being also bent or has someone else had this problem and managed to fix it???
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Id also be replacing the 'z' bar, i think its proper name is raduis rod?
    and also the lower control arm in case it too is bent.
    get the steering re aligned too
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    vp sedan
    Jun 2008
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    ve sv6
    Aug 2010
    ruf 231 is on the right track, also the front of the x-member where the front caster bushes goes into it can pull back, and also the x-member can move back, look at the nuts that hold the x-member in and see if there is any whitness marks from the x-member moving back. about how much is it back?
    vp sedan
    Jun 2008
    it's only a tad over an inch off the rear so it is definately out of whack somewhere!
    vp sedan
    Jun 2008
    no sorry not got photos at present. will post one later okay!
  1. Suspension Bracing for VS Sedan Live Axle
    By cwbyup in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2010, 01:49 PM
  2. [WA] WTB FE2 Suspension to suit V6 VT Commodore Sedan
    By andrew83 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-06-2010, 06:13 PM
  3. VS BT1 Fuel Tank And Suspension On A VK Sedan
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-10-2009, 07:42 AM
  4. 98 vt sedan sagging rear suspension
    By ports in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2009, 12:02 PM
  5. vs sedan and wagon same suspension ??
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2009, 08:47 PM
