Results 1 to 6 of 6
Thread: series 1 or 2
    VR 5LTR
    Mar 2009
    Bay of plenty
    Default series 1 or 2
    maybe a silly question but how do you tell between a series 1 and a series 2 motor from a vn - vp, is there any visual difference that i can look for, cheers craig, gonna put a v6 into my 2wd hilux be way cheaper on rego for me here in nz, cost us $600 to rego for a year then road tax as well
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Series 1 = the top radiator hose goes to the back of the manifold.
    Series 2 = the top radiator hose goes to the front of the manifold.
    Illegitimi Non Carborundum
    VR 5LTR
    Mar 2009
    Bay of plenty
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    both as good as each other in my opinion just the series 2 motor is easier to change the thermostat on with it being at the front of the manifold
    VN Calais With All The Factory Fruit I Need!
    Dec 2009
    First up there is no series 1 or 2 in a VN. There were loads of running changes with these motors, things like valve gear etc. So if you get a 1988 motor and a 1990 both with the thermostat at the back they won't be the same inside. The earlier ones had the thermostat at the back but that is not the only difference. The earlier ones will if not worn out be a bit punchier off the mark as they have a bit more low down so I am led to believe.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    As above, "S1" motor as some call it is what I had in my 88 Calais, more torque down low than any other stock Buick or Ecotec I have ever driven.
    Best RPG ever
  1. WM Caprice Series 1 Upgrade to Series 2 touch screen
    By 928S in forum General Discussion
    Last Post: 10-12-2011, 10:09 AM
  2. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  3. 2.5'' Catback Exhaust, series 1 engine in series 2 body. [With out extractors]
    By Raremetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2010, 05:46 PM
  4. wrecking VS CALAIS SERIES 2 INTERIOR + VS STATO SERIES 2 DOORTRIMS
    By petezor in forum Parts And Other Items For Sale
    Last Post: 07-05-2008, 10:50 PM
  5. Convertting to a series 1 engine from series 2 AND question about oil pick up
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2006, 07:37 PM
