Results 1 to 4 of 4
Thread: 92 VP Leaking Coolant and losing power
    1992 VP Wagon
    Jan 2011
    Yeppoon QLD
    Default 92 VP Leaking Coolant and losing power
    I recently purchased a VP wagon as my first car. Not long after I purchased it, during a night time drive the battery light kept coming on and the headlights would dim dramatically. I had the alternator checked and it was fine apparently, so they replaced the battery. All has been goodm, until now 4 months down the track, its doing it again And it is also leaking what appears to be cooland at my feet when I am driving. Its like having my own little swimming pool at my feet.
    Any one else experianced similar problems? Any guesstaments on what it may cost to fix???
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Probably ur regulator bushes on the alt as to y its throwing the batt light on. easy to check the bushes, take out the regulator its got a plug to it at the top of ur alt, 2screws holding it in, 30-40 to replace, just check if there is any bush left
    Where is the leak coming from? its most probably the heater tap, they are quiet common to snap where the hoses join, one will be broken
    DOH didnt see it was leakin at ur feet, it would be heater core
    ________________________________________
    93' Pov-Pac
    Jul 2010
    Coolant leak would definitely be a heater core/tap issue. May be worth pulling out the plastics underneath the dash to have a good look to see where exactly the leak is coming from.
    This thread should help you if you decide to pull out some plastics to have a look Stereo Install/Removal (VN - VS)
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Is it definitely coolant or just water? If it's plain water it's most likely a blocked drain pipe. Drain pipe can be accessed from under the car in the transmission tunnel (easier than removing the heater box). Just poke something up into it to remove any blockage. If it's coolant then it'll most likely be heater core or tap or hoses. Have a look under there and see if you can notice water running down the two heater core pipes from the firewall. If the water is coming from there look at the heater tap/heater tap hoses. If it isn't coming from there then it'll be the heater core. Hope for your sake it's the drain pipe as it's the cheapest/easiest to fix!
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
  1. losing coolant
    By bulldog79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2010, 05:08 AM
  2. Losing Coolant
    By benno9911 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2010, 11:16 AM
  3. VR losing coolant??
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2009, 07:50 PM
  4. VR losing coolant
    By robs_vr_ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2008, 01:07 AM
  5. losing coolant
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2008, 10:31 PM
