Results 1 to 12 of 12
Thread: VN Diff recommendations
    1994 VR 5 Litre Caprice
    Jul 2009
    Liverpool
    Default VN Diff recommendations
    What would everyone recommend as a diff for my 5 speed VN ? Motor is being fully worked so need something else in there
    VS Senator
    Oct 2009
    what engine is it running and how much power roughly will it put out at the wheels
    Jul 2009
    Liverpool
    its a 3.8 and not sure on the power
    it should be a pretty decent amount as I am going all out with the mods
    VS Senator
    Oct 2009
    in my old vn i used the standard diff with a kaaz 2 way lsd center. probably a bit of an overkill but i was sick of killing standard factory lsd,s. plus i knew that it would be able to take a lot of punishment and hold up well.
    Jul 2009
    Liverpool
    Jul 2009
    Liverpool
    VS Senator
    Oct 2009
    thats what i did. imo the standard diff aren't to bad. plus i wasn't chasing mega hp so a 9" would be an overkill and they are heavier. the kaaz brand new fitted with 3.46 gears installed ready to go was $2800 roughly from memory purchased about 2yrs ago
    VS Senator
    Oct 2009
    Quote Originally Posted by Rob&Krisseh View Post
    What about a mini spool ?
    street or track
    Jul 2009
    Liverpool
    VS Senator
    Oct 2009
    if its to be driven on the street frequently then i wouldn't go a mini spool but if its only to see the street every now and then with the cars main aim for show then a mini spool could be a good choice
    A bicycle
    Aug 2009
    Gippsland, Victoria
    mini spool is fine to drive on the street, just annoying and not roadworthy.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    Vn berlina, Vn calais
    Jan 2011
    Hi mate If i was running that set up I would go with a Standard LSD with VL 3:45 gears or a really cheap way would be to just weld the diff and run the same Vl gears and save some money.
  1. 04' sv6 mod recommendations
    By yandan in forum V6 Development And Modification
    Last Post: 10-01-2010, 04:15 PM
  2. After a new sub, want recommendations
    By bezz in forum Car Audio
    Last Post: 03-05-2009, 10:19 PM
  3. VR Ute recommendations
    By Rock On in forum Car Audio
    Last Post: 22-08-2005, 04:57 PM
  4. Recommendations
    By hindred in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2005, 10:33 PM
