Results 1 to 4 of 4
Thread: VN Wheel Alignment
    VN Calais
    Feb 2009
    Default VN Wheel Alignment
    Hey guys, I got a wheel alignment on my vn a couple days before christmas and I got told the following things require attention.
    - Bearing Plates
    - Radius Rod Arm Bushes
    - Rear Traling Arm Bushes
    - Penard Bushes
    As im not too sure what these are especially the Bearing Plate, I have some brand new bushes but not sure if these are the ones, so im basically wondering what these parts are location on car ect, any help is much appreciated. Also when im riding in the back of the car on the hwy doing 100km or more you can feel the rear just swaying like your on a boat although you can't feel it when your driving just when sitting on the back seat.
    Also the electric fan is not working at all, the car will overheat if it is not being constantly driven at speed cause when im at lights or in traffic and the car is idoling the fan wont cut in. I have been told it is the relay be cause the fuse is good. Any help with these issues would be very much appreciated, Thanks guys!
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Id personally take it back and get them to replace it for you, Might cost a bit extra.. But they stuff something up, at-least you can take it back and say there's a problem.. Say if you did it.. Could end up costing more then it should if you stuff something up.. I'm only saying that only personal experiences.. BUT, take a look on google.. Should find some information about it..
    If its the relay, Swap it for say the Headlight relay, and test it out
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    lein's Avatar
    lein is offline Comrade Commodore
    VZ Ute
    Dec 2010
    Tropical QLD
    Here go, some pictures to help ya.
    edit: the strut mount is the bearing plate in this instance.
    I aim to misbehave.
    VN Calais
    Feb 2009
    Hey, thanks for the info, ive been busy with work I'll have a look and try these things either friday afternoon or saturday. Thanks will let you know how I go.
  1. tried to get wheel alignment done
    By sedgewik in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2010, 06:22 PM
  2. Wheel Alignment
    By magg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2009, 01:29 PM
  3. Wheel Alignment?
    By CommVTS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2009, 11:40 PM
  4. Wheel Alignment
    By VSTrev in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-10-2008, 08:28 PM
