Results 1 to 3 of 3
Thread: -8 lines from vn fuel tank.
    vn commodore
    Jan 2011
    brisbane
    Default -8 lines from vn fuel tank.
    hey guys,
    im wondering if any one knows how to get around this issue. i need to run half inch (-8) fuel line from my standard vn fuel tank to my in boot surge tank. how ever the standard fuel sender unit doesnt allow for any thing bigger than -6. ive looked at welding a -8 fitting onto the tank but cant figure out how the pump is going to get the fuel to the weld on fitting.
    any ideas.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Where I used to live there was 2 specialists that do that kind of thing, hoses and joiners and custom jobs. One was called ENZED ENZED Australia - Service Centres click on QLD.
    The other one was called (something)link, they are also Australia wide but sorry I cant remember the name.
    I hope ENZED is useful to you, they do pretty much everything and at cheap prices.
    Best RPG ever
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I made this fitting using some 5/16 fuel line and a short bit of old power steering solid pipe and silver solder and the right angle pre bent rubber hose from the charcoal canister from any vn/p/r with a couple of hose clamps for my vh that needed similar difference in its fuel hose sizes when we fitted a different tank for the fuel injection and it worked fine....when I went to enzed here.....they didnt have a clue so I had to make it.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Petrol Tank breather lines
    By commy vk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-06-2010, 08:01 PM
  2. fuel lines and reg
    By CM99VT in forum V8 Development and Modification
    Last Post: 29-11-2009, 02:35 PM
  3. VS Fuel Lines, where to buy?
    By Cobez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 08:02 PM
  4. how do i take my fuel lines off
    By MON57A in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 12:55 AM
  5. Best way to clean fuel tank & lines??
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2005, 12:58 PM
