Results 1 to 12 of 12
Thread: vp break light issues
    VP Calais S2 V6
    Jun 2010
    Victor Habor S.A.
    Default vp break light issues
    hey all i just got a vp berlina fully optioned everything works but the break lights wont work has new globes and fuses but still dont work? Any ideas ?
    Maroon/Silver 93 VP Calais Coilovers, 18" VY SS Mags, Big Brake Upgrade, IRS , ABS , Heavy Duty Sway Bar Links, Cold Air Intake Project Midnight Whipple Turbo On Its Way
    93' Pov-Pac
    Jul 2010
    Do the tailights work?
    Have a look at the wiring and the globe holders, there could be wear or corrosion. If youre handy with a soldering iron and have a multimeter on hand, you can always cut off the wires to check to see if there is current coming through them.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Ur bulb holders will be corrored, can try sand em back so its not rusty, never worked for mine tho.
    I just went round to wreckers grabbing what looms i could so i could make one good set.
    Its very rare to find a vn/p tail light loom that isnt rusted out
    ________________________________________
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Also, check the brake switch under the dash. Little white plastic switch above the brake pedal, with two wires going to it. I've had a faulty one before. Just something else to check. Do the Indicators (rear) work??
    VP Calais S2 V6
    Jun 2010
    Victor Habor S.A.
    everything works aside from the brake lights if i turn the lights on they come on like normal but still dont light up when the brakes are pressed
    D22 St-r Navara
    Dec 2010
    perth
    Quote Originally Posted by jakeydee View Post
    as previously said its would be the brake switch on the top of the brake pedal arm.
    VP Calais S2 V6
    Jun 2010
    Victor Habor S.A.
    well i had 2 in there... Just transfered wires swapped wires over and worked first time thanks heaps guys! I also have a problem with my elect windows passenger side works front and back no worries but neither drivers side ones work i have taken the door panels of and up close you can here it try wind up but down button i get nothing! ? Only tested the front so far but any ideas?
    VP Commodore
    Feb 2008
    Leda, WA
    here is a good one.
    last week my brake lights just stopped working. i checked everything i knew of. fuses, bulbs etc.
    then i left the car running at night with the headlights on and when i came back to the car i noticed that the brake lights were on.....
    so i did some more investigating but came up with nothing. then all of a sudden the break lights started working normally?!?!?!?!
    so does anyone know of this issue? i drive in peak hour morn and arvo and hate the idea of them cutting out again.... because perth drivers suck and have a habbit of sitting about 3mm from your boot.... thanks guys....
    philip_rawoz@yahoo.com.au
    RawOz Photography, specialising in nature and motorsports.
    VP Berlina LX
    Jul 2010
    pipzryd, i havnt had quite the same problem, but i would be checking the brake light switch on the pedal (referred to above), my car has two, one for lights and one for cruise control, and at times both have just slipped back in their mounts making the pedal not press the switch.
    If after installing your new stereo all you can hear is rattling, you need a louder stereo.
    VP Commodore
    Feb 2008
    Leda, WA
    cool cheers ill have another look, i was wandering why there was multiple mountings for them.... love your signature... lol
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    my daughter's VP had faulty earth connections in the tail-light bulb holders. Brake lights worked until the tai lights were switched on but not when the lights were switched on. I watched a licensed mechanic install a new earth connection by drilling up the side of the light fitting, soldering in a new wire and connecting that to the earth wire a short distance back up the wire (to the earth). Very quick and efficient and fixed the problem. Previously the tail-lights had just dimmed when the brakes applied.
    VP Calais S2 V6
    Jun 2010
    Victor Habor S.A.
    just for all i done some reserch and asked a few mechanics and they have all said most common fault leading to this problem is the switch at the brake peddle either not being depressed as the brakes are applied or that same switch faulting... if you have cruse control you can try the second switch there(Just switch wires over) to check if not short the wires and the brake lights should come on. not for everyone but is a start. mine was faulty switch and i picked a second hand one up for 2$ at the wreckers.
  1. vt break caution light
    By vn nut in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2010, 12:16 AM
  2. Wiring for the wing break light
    By RedBull77 in forum Electrical Wiring / Questions
    Last Post: 24-07-2009, 03:40 PM
  3. Break light issue
    By LUMINA ANIMUL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2007, 04:28 PM
  4. Break light
    By Ristof in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-04-2006, 01:17 PM
  5. VU sports bar break light
    By Bowdz in forum Electrical Wiring / Questions
    Last Post: 11-11-2005, 02:34 PM
