Results 1 to 9 of 9
Thread: vp 5 speed clutch fork taps on bellhousing
    vg ute v6 5 speed
    Jun 2008
    Default vp 5 speed clutch fork taps on bellhousing
    i got a vp 5 speed and the clutch fork taps on bellhousing, i've only had it a month a brought it with a stuffed clutch since been replaced, it only does it at about 2000 to 3500 revs at a guess, but is really annoying.
    any help would be great,
    thanks
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    This means that the pivot ball height (inside the bellhousing) is incorrectly adjusted. For this to happen i'd bet u installed a heavy duty clutch yes?
    So if you can put up with it, do so... if not, its a gearbox out job
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    vg ute v6 5 speed
    Jun 2008
    hey yeah i put heavy duty clutch in it..... so this pivot ball how do you adjust that, i have to its doing my head in lol
    thanks for the info
    VN SII And VQ SII
    Sep 2005
    Melbourne VIC
    This is generally caused by the two absorbsion rubbers being worn out on the fork, where the release bearing sits. it prevents the fork from centering properly beacuse there is too much play, then rattles on the belhousing.
    If you google vn clutch fork rattle, the excedy clutch site has a good explaination of where these rubbers sit.
    Please PM me if you know of any L67's complete with loom and ECU are for sale
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    To adjust its quite easy as its like a threaded rod lossen of locking nut and adjust
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    GTP 85's Avatar
    Aug 2006
    In regards to the rubbers for the clutch fork, i wouldnt even bother to be honest.... Tried putting in new rubbers- flogged out in no time. Then went to the trouble of machining up some nylon like plastic (i forget the name now...), put them on and flogged them out too.
    So in the end i just chucked the fork in my bench vice and gently pressed it til it could every so lightly hold on to the thrust bearing.. problem solved
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    mine used to do this but only over a very small rpm range, when i changed the clutch i filed out the slot in the bell housing just a little. also, what condition are the engine and trans mount in? also have a good look at the harmonic balancer.
    Body by Holden, Soul by Brock
    the Legend will live forever
    D22 St-r Navara
    Dec 2010
    perth
    could also be a snapped/bent clutch fork . sheared mine off without trying
    vg ute v6 5 speed
    Jun 2008
    i replaced the two little nipples as you guys said and measured the pivot ball, put it back together and bam all good no freaking rattle.
    but.... there is a now a vibration through the gearbox tailshaft area, everything is done up tight what could i have not lined up right????
    thnks for the help so far
  1. T5 Clutch Fork Needed!
    By SS Robster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2011, 01:20 AM
  2. VS S1 Clutch Fork !!
    By surrealistic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2008, 05:51 AM
  3. Vn Clutch Fork ????
    By wayne_140 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2008, 06:03 PM
  4. Where to buy a clutch fork these days?
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2008, 08:09 PM
  5. clutch fork
    By wombat1961 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2005, 03:57 PM
