Results 1 to 3 of 3
Thread: Rough idle in gear, trans prob??
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Unhappy Rough idle in gear, trans prob??
    Hey all wen i select a gear and wen foot on brake in my vn auto the rpm is low and sounds like car will die sometimes it just goes up and down from 300-900rpm then finds it self around 800-900 steady rpm does it all the time it ranges in how bad it does it iv done a trans sevice on it but hasnt fixed it posible trans probs was reading sumtin like this nd they said vacume leak from posible brake booster diaphram?? Also if i check the fault codes if sumtin rong with trans will it show a fault
    Cheers guys its shittin me heaps
    89 vn calais v6
    Oct 2010
    have you checked your iac they can get full of crap and stuff up your idle try taking off your throttle body and giving it a good clean with carby cleaner also your idle may be low have you tried changing the little screw the the back of the throttle body and see how that affects it. dont forget to reset your iac after you do the throttle body by putting in park and holding at 3000rpm for 10 secs.
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Wouldn't recommend carby cleaner on the IAC itself though. Get some of the spray that's designed especially for cleaning electronics. CO2 cleaner I think it is.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. Rough idle in gear
    By Freshjivin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 01:59 PM
  3. my auto vr trans prob!
    By gareth89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2009, 06:06 PM
  4. rough idle / misfiring after trans service
    By petec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 11:51 AM
  5. 304 idle prob
    By SLE 500 in forum V8 Development and Modification
    Last Post: 10-05-2008, 02:25 AM
