well my factory immobiliser is cactus so i got a vp ss one with key and remote. where is the unit located so i can swap out the black box with new workin one..
thanks in advance
MADE OF METAL NOT RICE
On a Statesman (and Calais) the theft deterrent function is carried out by the BCM. The BCM is behind the fuse cover, under the dash adjacent to the steering column.
You want a BCM with part # 92040021, up to 15/7/92 or #92044847 after 15/7/92. I think that SS BCM is berlina level; #92045536. If an SS uses the executive anti-theft system it will have a separate module normally mounted above the glove box.
thanks for that. appreciate the help. will look into next time i am at my mates wreckers.. cheers
