Results 1 to 6 of 6
Thread: water collecting on drivers side floor when aircon used alot
    1991 vp v6 sedan
    Feb 2011
    huskisson
    Default water collecting on drivers side floor when aircon used alot
    would anyone know where the water is coming from,must be from the aircon somehow
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Sounds like a blocked drain pipe. When the air con is used it creates condensation around the evaporator core which is inside the heater box. This condensation is supposed to run out the drain pipe in the bottom of the heater box and out the car. If it's blocked it'll pool in the drain pipe and overflow into the drivers foot well. Particularly when turning left.
    Easiest fix is to get under the car and attempt to unblock the pipe with something thin and solid (coat hanger worked for me). The drain pipe is located above the transmission in the roof of the transmission tunnel on the passenger side. It can be a bit hard to spot until you know what you're looking for but there isn't much else around there anyway. Good luck.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    VP SS, Cammed VN V6 daily
    Jan 2010
    ^ 2nd that! seen it before, coat hanger and some anger will fix it up, maybe have some band-aids to fix your knuckles up after.
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    If your going to stick anything up the drain be careful not to puncture the evaporator as that will cause alot more problems
    vs commodore
    Oct 2009
    Tamworth NSW
    The workshop manuals say not to use wire or anything hard because of the A/C evaporator as mentioned above,it recommends using a long plastic zip tie or similar to clear the drains.
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Shouldn't need to poke it up that far to unblock it. Theres a bit of distance between the opening and the core. But it is better to be safe than sorry
    1. 1990 VN Exec V6
  1. pls help:Water leak passenger side floor
    By scottyz999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2012, 04:34 PM
  2. Wet drivers side rear floor ??
    By MZMRIS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-09-2008, 08:37 AM
  3. blocked aircon drain - leaking in the car on drivers side
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2008, 07:10 PM
  4. Water on Drivers Side Floor.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2007, 01:23 PM
  5. blocked aircon drain - leaking in the car on drivers side VR
    Last Post: 24-12-2006, 05:42 PM
