Results 1 to 6 of 6
Thread: Front end rattle
    Vp series 1
    Jan 2011
    Default Front end rattle
    Hey i have a 91 vp, its got knock/rattle in the left front..
    Could it be steering rack ? Or something to do with suspension, it also shudders when u turn hard right..
    Wat could it be?
    VP Commodore Executive
    Jul 2010
    South Coast, NSW
    Does it do it when you go over bumps too? Check the struts, I just replaced mine when I had a knock kinda like what you are describing.
    VB SL/E
    Dec 2008
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Could be: Ball joints on bottom A-arm, castor rod bushes, tie rod (steering link to stub axle) ends, strut (shocks).
    Jack the car up on the appropriate side following owners manual or workshop manual directions and common sense in order not to die. ie chock rear wheels, use proper jacking point, dont stand the jack up on bricks to get more lift, preferably put spare wheel under sill as life preserver, use chassis stands etc.
    Leave the road wheel on for leverage and see where you can find play in the suspension shoving it with your foot if necessary with someone holding the steering wheel steady.
    Next take the wheel off and use a large pry bar or wheel brace to lever on stub axle and find out what's going on.
    Most suspension parts should be changed as pairs ie left and right side at the same time to preserve symmetry in front end.
    Most parts are available as change overs to avoid having to press in bushes or you can take the parts to pedders and they'll supply the new bushes and fit them to the component for reasonable price.
    Don't assume you can press in bushes with a vice, you might stuff them. Ball joints best done as change over A arm, comes with new bushes too that way.
    If your struts are stuffed either get the work done or get a service manual and follow safety directions closely (rather than catch the spring with your face)
    Good luck mate.
    Warranty Void
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check your swaybar link pin bushes too.
    Visit my Facebook page
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I had a similar noise turned out to be a passenger seat bolt had come a little loose from the floor and when I had a passenger it made the noise which i definately thought was the front left suspension (fitted s1 statesnman seats about 6 months ago), tightened it up with loctite and its good now. just something to check if you can't find any other problems hehe.
  1. Front end rattle...
    By =bullet40= in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-08-2009, 11:39 PM
  2. Knock/Rattle in Front Left
    By howie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2008, 11:45 PM
  3. Rattle in front end
    By Nanos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2008, 08:58 AM
  4. Rattle in VH front end??
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-01-2007, 10:34 PM
  5. Rattle in front of car???
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2006, 12:00 PM
