Results 1 to 8 of 8
Thread: where is the vq body control module
    vs ute 97 s2
    Mar 2007
    Default where is the vq body control module
    hi i just bought a vq statesman of a wrecker and i didnt get a key iv alreasy got all the parts i need i just need to find the body control module iv looked under the steering coloumn and it wasnt there dose any 1 know where it is thank you
    VX 'S' S1
    Apr 2005
    South East,Victoria
    vs commodore
    Oct 2009
    Tamworth NSW
    The ECU is behind the passenger side kick panel,not the BCM.The BCM should be in near the fuses etc behind the panel under the steering column.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    What year VQ statesman did you buy?
    Series 1 (Grey/Blue Dash) Series 2(Black Dash)
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    vs ute 97 s2
    Mar 2007
    hi its a 1990 model blue dash its not where the fuses are and the ecu is behind the passenger side kick panel i have the remote to turn off the immobiliser but i just cand find the bcm
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    vs commodore
    Oct 2009
    Tamworth NSW
    I know that some model VP's didnt have a BCM,they used seperate modules for the different systems, if your car does have a BCM,there should also be an ALDL connector under the dash there somewhere near the fuses, this is so a a Tech 1 scantool can be connected to the BCM for diagnostics.It should be the same plug as the ECU ALDL connector near the ECU.On the later models,the BCM, ECU,ABS and SRS all use the same ALDL connector for diagnostics ,but the VP's that have the BCM have 2 seperate ALDL connectors...If it doesnt have the one under the dash near the fuses etc,it doesnt have a BCM fitted.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by DOWNVS View Post
    Hey bud, Yours is a Series1 VQ Stato, They Don't have a BCM module, All their setups are seperate modules.
    Mat
  1. Vy s body control module
    By 5LTRVNSS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2011, 11:08 AM
  2. body control module
    By tigersrule in forum Electrical Wiring / Questions
    Last Post: 25-08-2010, 01:20 PM
  3. Body Control Module
    By stockvk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2007, 06:33 AM
  4. Body control module
    By spazdan01 in forum Electrical Wiring / Questions
    Last Post: 07-05-2006, 12:30 AM
  5. Body control module. What is it and what does it do???
    By kojamoz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2006, 08:14 PM
