Results 1 to 17 of 17
Thread: eaton m62 supercharger vacum lines
    vp berlina v6 manaul
    Apr 2009
    Default eaton m62 supercharger vacum lines. help?
    hay all iv just fitted a m62 supercharger to my vp v6 and im a little stuck when it comes to the vacum lines im unsure where to run the vacuum lines from the bypass valve any pics of a setup would be great or info on where the vacuum lines run to cheers
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    vacuum should be after the charger i beleive im not 100% theres a couple of guys on here that run m62 prolly best to pm them and ask
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Sounds like an interesting little setup there mate
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you can just tie the valve shut most people disable the control valve anyway
    Apr 2009
    Quote Originally Posted by RUF 231 View Post
    cheers ruffy
    Apr 2009
    Quote Originally Posted by delcowizzid View Post
    ill consider that but id rather run it properly really just need to no where the vacum lines come off the bypass valve and the run to ?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Bypass valves improve fuel economy and drivability less stress on charger and improves life of charger i dont why youd block it off.
    So you dont even know where the vacport is on the charger?
    Apr 2009
    Yeah I do there's a vacum multi tap on the manifold.
    And bypass valve has 2 vacum post so you reckon
    just run the lines to the multi tap vacum post
    в∞ѕтεכ √&
    Jul 2008
    NZ
    hes got no solinoid or outputs on the ecu to power the solinoid makes it harder i bypass every L67 valve get boost earlier and way more of it still drive stock when off the gas
    Apr 2009
    Quote Originally Posted by vpfury View Post
    Sorry meant the multi tap is on the charger
    Apr 2009
    It's a vacum operated bypass valve
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    ok so there 2 vacuum lines for the bypass? if thats the case id say one goes on each side of the charger as it will compare pressure on each side and open/close accordingly
    Apr 2009
    Quote Originally Posted by Pub247 View Post
    Ok that makes sense cause there's a vacum multi tap on the left hand side of the charger and a single vacum spot on the right side so that's how it works hay
    Apr 2009
    If any one has pictures of their setup showing vacum lines it would be great just wanna see how every thing is setup just to make sure iv got it all right
  15. #15
    Jul 2008
  16. #16
    Apr 2009
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    mate go into the vn-vp my ride threads theres 2 poeople in there that have chargers on their cars
  1. Eaton m62 supercharger on a vp v6
    By frdhtr in forum V6 Development And Modification
    Last Post: 16-10-2010, 09:27 PM
  2. [QLD] eaton 112 supercharger
    By eaton v8 in forum Parts And Other Items For Sale
    Last Post: 20-07-2010, 06:52 PM
  3. eaton m90 supercharger to vk
    By XMY308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-05-2008, 01:01 AM
  4. Eaton M90 Supercharger
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2006, 12:15 AM
  5. Eaton M-90 Supercharger
    By James Collins in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2004, 12:18 PM
