Results 1 to 15 of 15
Thread: vp tacho
    vp 3.8
    Jul 2005
    charters towers
    Default vp tacho
    Have been trying to put in an aftermarket tacho for a while now and can not get it to work. Found the signal wire ( brown one ) near the strut and it wont work. Put a multi meter on it and it is showing a signal.. Even went to the coil pack to get the signal wire (white one ) and still no go.
    Help
    vp 3.8 lt lowered T70 turbo 38 mm wastegate running 14 psi making 253 rear wheel kw lsd 3.08 gears. tuned by delcowizard
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    you hooking up the power and ground on the tacho.. as well as the sense wire..?
    vp 3.8
    Jul 2005
    charters towers
    yeah . tried the tacho in a friends ford ( my bad ) and had no trouble.
    May 2006
    Perth, Western Aust
    hmm bit odd... you could always try the tacho wire behind the instrument cluster as well...
    vp 3.8
    Jul 2005
    charters towers
    might give that a go tonight.
    May 2006
    Perth, Western Aust
    spose the only other issue is where are u tapping into for your power and ground wires... have u tried direct off the battery just to be sure..
    vp 3.8
    Jul 2005
    charters towers
    yeah i have. the tacho in my dash died today as well
    VP Exec. SII Manual
    Feb 2009
    haha i know the answer to this i did it a while a go to mine ...
    You have a coil pack! most aftermarket tacho's run from a distrubutor which is a complately different type of signal!
    I found that brown wire and that white one and tried them to haha.
    I made my self a digital one if you wanna buy it from me because I instead bought a new dash (my manual vp didnt come with a tacho, sucks).
    Long story short it wont work !
    VP Exec. SII Manual
    Feb 2009
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by JacobD_10 View Post
    Or fit the factory tacho. 10 min job.
    and 3 Dangerous non ABS VN's
    VP Exec. SII Manual
    Feb 2009
    Quote Originally Posted by 88GreenVN View Post
    Quote Originally Posted by sv6mad View Post
    as long as he has one its ten minutes.
    But yes ofcourse that is an option.
    You will most likely have to buy a whole new cluster, or you could repair yours (work out what happened).
    Doubt you will find just the tacho section.
    vp 3.8
    Jul 2005
    charters towers
    someone hooked me up with a tacho , will wait for it and rebuild mine.
    vp 3.8
    Jul 2005
    charters towers
    does any one know if the fuel gauge and temp gauge are the same.
    88GreenVN's Avatar
    Jun 2006
    The same as in you can run a VN VP VR or VS temp/fuel gauge in a L2 cluster and they will work.
  15. #15
    vp 3.8
    Jul 2005
    charters towers
    yeah i just put a temp gauge out of a v8 L2 dash into my v6 L2 dash as a fuel gauge. seams to be workig.
  1. Have I got a L3 V6 or V8 Tacho
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2010, 09:05 AM
  2. hsv tacho into berlina 5.7L standard tacho
    By genaero20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 04:08 PM
  3. where to put my tacho?
    By aussie_cruzin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2009, 09:35 PM
  4. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  5. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
