Results 1 to 11 of 11
Thread: Service - How To
    VX R8 Clubsport
    Feb 2005
    Default Service - How To
    Hi All,
    Its time for a service again (done 15,000kms since last service...).
    I've always taken my cars to a mechanic to do the services, however this time, with cash being extremely tight, am wanting to do it myself (I am building a house, for anyone that has done that before, you will understand...).
    Can anyone please give some advice on how to do a simple service that will keep me running until I can get the cash to do a major with a mechanic.
    I am assuming I will need to:
    * Change oil
    * Change oil filter
    * Change spark plugs
    * Clean/replace air filter (simple job)
    * anything else?
    I just changed the spark plug leads about 5,000 kms ago, and have just put in a new radiator, so coolent etc is all good. I also changed the brake pads about 4 months ago.
    I am fairly competent with simple mechanics (after having done all that myself), its just I have never actually done a service!
    Any advice and pointers to keep my running for the next 6 months would be highly appreciated.
    3.2ltr car
    Sep 2005
    East Melbourne
    if its a v8 change the dissy cap and rotor button. for 30$ makes a big diff
    if the car hasdone a few k's perhaps run a 0.1mm less gap on your plugs that they recommend.
    BR377 Guest
    CLE
    CLE is offline
    Mar 2005
    I thought that you would:
    1. Change oil
    2. Change oil filter
    3. Check air filter
    4. Check diff oil
    5. Check tranny oil
    6. Check brake fluid
    7. Check battery (unscrew all of the caps and ensure all of the levels are correct)
    8. Check power steering fluid
    9. Check all the essentials - lights, indicators etc are working....
    That's all I can think of at the moment.
    VX SS
    Oct 2004
    Mandurah W.A
    um changin engine oil.... drop sump plug.. let it drain... if your going to do oil filter aswell get a filter remover.. or do wat i do stab a screw driver into the side and twist it off like that... put new filter. just run a film of oil around metal seal on the filter then reattach.. fill her up... im guessin u have a v6 so 3.8 litres is required (yes it is the same!! cowincidence aye)
    um wat else.. plugs out plugs in simple.. unless u ahve k & n u will need new filter..
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I agree with CLE - I'm a tight bugger and all I do for a service is change the oil and filter. That costs about $12 for oil and $6 for filter. Check all the vitals but only change/replace if worn badly. Good luck with your house - the pain you go thru to pay it off is all worth it in the end.
    VX R8 Clubsport
    Feb 2005
    Thanks guys for your pointers.
    When it comes to oil, what do people recommend? I was looking at Castrol GTX-2 and GTX-3. GTX-3 has a rating of 15w-40. is this okay for an 89 vn? or is it too thin of an oil. I was after an oil which would lubricate fast on cold mornings, as I start work in the wee hours of the day when its bloody cold, and the old calais don't like it much....
    VX SS
    Oct 2004
    Mandurah W.A
    VX R8 Clubsport
    Feb 2005
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Jul 2004
    dont bother with cheap kmart oils i use penrite hpr 15 its 15w60 costs 30buks semi synthetic great stuff definately change oil filter 15,000 is abit over due just give it a good check over top up fliuds etc spark plusg air filte fuel mite not be necessary if u have a history check when they were done spark plugs good for 20k i think fuel filter 40k air filter is easy to check yourself
  1. 30,000 service
    By Stretcher Bearer in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-09-2007, 09:30 AM
  2. How much for 60k service?
    By maginoodle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-04-2007, 06:57 PM
  3. service due
    By oliver in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-01-2007, 09:51 PM
  4. Service
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2005, 11:16 PM
  5. My First VR Service
    By ccassie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2005, 03:17 AM
