Results 1 to 22 of 22
Thread: v6 vp berlina help needed
    VT Calais 5.0ltr
    Jan 2011
    canberra
    Default v6 vp berlina help needed
    hi all ,
    need help!! Put new extractors on v6 vp after headder cracked now wont run properly ?
    back fires coughs and splutters when under load feels like it wants to go but just cant revs and no go?
    idles great and free revs fine.
    checked sparks & plugs leads extractor bolts all good
    any ideas ?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    D22 St-r Navara
    Dec 2010
    perth
    Quote Originally Posted by ucwepn View Post
    oxygen sensor?
    would be hilliarous if he has left it off
    VT Calais 5.0ltr
    Jan 2011
    canberra
    VT Calais 5.0ltr
    Jan 2011
    canberra
    vs commodore
    Oct 2009
    Tamworth NSW
    The oxygen sensor wont cause it to run crook and misfire etc,even if its not working at all.Were the plug leads removed when you did the manifold.Id check to make sure they are on the right cylinder numbers.If they are silicon type plug leads,they can be easily broken if pulled too hard whilst removing them from the plugs or getting them kinked tightly,when I say broken,I mean it can break the carbon core inside the lead which makes the lead useless under load,it will just cause a misfire under load or power.It really doesnt take much force to break the carbon core, especially if they are a bit old.Ive done it a couple of times over the years..
    VT Calais 5.0ltr
    Jan 2011
    canberra
    KiwiHoldenDriver is offline Loud, proud Kiwi
    VT Olympic Spec V6
    Jan 2008
    Auckland, New Zealand
    Quote Originally Posted by Brett_jjj View Post
    Agreed. This occurred with an old Toymota my mum used to own. Idled fine but as soon as a load was put on it, it misfired until the it was no longer accelerating then the misfire disappeared. Swapped out the leads and it ran as well as could be expected. Also check that the spark plug leads are firmly seated as there may be enough contact for idle operations but not for loaded operation.
    VT Calais 5.0ltr
    Jan 2011
    canberra
    replaced the leads . but still back firing under load ?
    could it be one of the coil packs?
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    leads on in the correct order,, kinda of an obvious thing but is something that i have done before when i was in a rush..
    Signature Goes Here
    VT Calais 5.0ltr
    Jan 2011
    canberra
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    I had the same thought about plugs leads in wrong order when I read the first post. It is really easy to get one wrong double and triple check. The cylinder no.s run front to back passenger side 1, 3, 5 and Driver side front to back 2, 4, 6. My coil packs are numbered. so it is easy to check. Let me know if your coil packs aren't numbered and I can help out with that info. I guess it is possible that your coil packs have been replaced/swapped around and could be misleading. Check another commodore if unsure
    VT Calais 5.0ltr
    Jan 2011
    canberra
    replaced & checked leads are all on in the right order as long as the coil packs are in the right order ( there numberd ) checked coil packs with multi meter all good.
    replaced o2 sensor
    STILL COUGHING AND SPLUTTERING UNDER LOAD WHEN WARM?
    PLEASE HELP !!!!!!!!!!!!!!!!
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    What suburb of Canberra are you in? I'm over at Jerra if you want someone to look it over for you.
    Illegitimi Non Carborundum
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    The firing order for the V6 is 1 6 5 4 3 2. If the plugs and leads are all ok,and you have the firing order right,then next Id be testing the coils, one at a time, by fitting a known working coil to where each of your coils are, and driving it each time to see if it makes any difference.These coils can sometimes show up ok when tested with a multimeter,but still cause misfiring and breaking down under load.Ive been caught out like this before with these coils.I now keep a new spare coil, just for testing purposes.Also if you find that if one coil is faulty,then its best to replace all 3 coils with either genuine holden coils, or a good brand aftermarket coil like MSD.I know there are "cheapie" coils available,but Id stay away from them,Ive seen a few problems caused by cheaps--t coils,so sometimes they dont work out cheaper in the long run at all..
  16. #16
    FXST01's Avatar
    VP V6 Auto Sedan
    Jun 2005
    MMMM, must a have sorted his problems out, a follow up would have been nice though.
  17. #17
    VT Calais 5.0ltr
    Jan 2011
    canberra
    sorry been away. still havent fixed the problem but the only thing i havent changed is the coil packs so i will let you know of the out come as soon as i can afford to replace them ?
  18. #18
    vn 5ltr execitive
    Feb 2011
    beenleigh
    i have notice u have said when warm if that is only when it dose it try replacing the cool temp senser under the tb that can cause problems like ur haven
  19. #19
    FXST01's Avatar
    VP V6 Auto Sedan
    Jun 2005
    Quote Originally Posted by sparksy07 View Post
    So what Suburb you in? I have my spare coils and my old temperature sender here if you want to eliminate those problems without paying for something you possibly don't need.
  20. #20
    VT Calais 5.0ltr
    Jan 2011
    canberra
    Quote Originally Posted by FXST01 View Post
    Thanks for that i live in holt in the golf course.
  21. #21
    VT Calais 5.0ltr
    Jan 2011
    canberra
    Got 1 new coil pac. been swaping and changing to see if it is just a nackerd coil pack ihas run heaps better so as soon as i can i will keep replacing 1 by 1 .
    still a bit of back firing under load when warm .
  22. #22
    VT Calais 5.0ltr
    Jan 2011
    canberra
    Like to Thank all who helped figure out the problem with my VP Berlina ended up being the coil packs !
    runs like a dream now.
    so thanks again to all who helped ....
  1. HDT Berlina, Help needed.
    By LeeoD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2010, 05:37 PM
  2. Multiple problems + stuff needed for my Berlina
    By vl_2010 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-12-2009, 03:18 PM
  3. [Help Needed] Holden VN Berlina Wagon (Want to buy keyless entry!)
    By Excale in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2009, 04:18 PM
  4. Help!! VY Berlina interior parts needed (seats)
    By jedas in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-03-2009, 12:34 PM
  5. HSV/Calais/Berlina Boot Mould Not Sitting Properly! Help Needed
    By finnbe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2007, 03:16 PM
