Results 1 to 8 of 8
Thread: 304 EFI V8 Timing Setting
    Snitz92 is offline LPG Sucks.
    '99 Subaru WRX, '89 Nissan 300ZX V6TT Targa
    Apr 2009
    Ceduna
    Default 304 EFI V8 Timing Setting
    Hi, on my VQ I am having LPG removed and would like to know what I need to do to change the ignition timing setting back to 10 or 11 degrees before TDC. I am still learning things about my car. I have a timing light and lots of tools. If possible could someone please list a basic walkthrough of what exactly i need to do to achieve this timing change.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Need to pin out at the diagnostic plug, i think it would still be in the passenger kick panel on VQ.. black and white on my VN
    take the driver fuel rail cover off the engine. reach down behind the engine between the dissy and the firewall, should feel the locking bolt for the dissy. Some cars have a 13mm bolt, mine has a 14mm. Crack the bolt and back it off about a turn.
    Rig the timing light up (assuming u know how to do this). On the balancer there is like an indent timing mark that you have to find, mite take a few hits on the starter motor to see it. Mark it with white out or a chalk texta.
    Start the car and let the idle settle, now check where the timing is at. Big long mark on the timing case is 0. Looking at the front of the engine, to the left of that mark is advance in increments of 2. Sus where the timing is at before adjusting. Counter clockwise on the dissy is advance, clockwise is retard (hope im correct.. i only just did mine duh), but you will see which way is which as you adjust it. Personally i always adjust it when the engine is off, start it to check. when you're happy lock the bolt back down. and recheck it.
    then you can pull the pin out of the diagnostic plug.
    Theres many more detailed how to's on here im sure
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Is it the same on VT 5Ltrs Excluding the diagnostics plug)?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vt is the same and the diagnostic port is under the stearing colomn
    Apr 2009
    Ceduna
    Ok, thanks mate, will check it out mid-week and let ya know. Since it's on a VQ Statesman, I reckon the firewall is more jammed up on the dizzy and inlet manifold. There's probably room for half the thickness of my hand to fit down behind manifold... Reall bitch of a set up but oh well, I'll suss it out.
    GTP 85's Avatar
    Aug 2006
    Its pretty tight on all of them cause of the heater hoses, vac etc. You will only have enough room to squeeze your left hand down there
    Apr 2009
    Ceduna
    Yeah f**k oath. I managed to instal some new spark plugs, ignition leads and coil lead (somehow!) and is running smooth as. Still on LPG and timed for the LPG but hopefully not too long before the tank and system is gone. Need more boot space to design a boot install for the sub and spare wheel to neaten it all up nice.
    VS SS 5L
    Oct 2008
    Short 14mm or 9/16th spanner you want it running front to back accross the top of the gearbox type thing not much room but doable...definately need a nice short spanner though.
  1. Timing Setting LPG 5L
    By Snitz92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2012, 10:10 PM
  2. setting timing on modified carby 202 black
    By zaczac in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2010, 08:23 PM
  3. 304 Setting timing
    By deanos70 in forum V8 Development and Modification
    Last Post: 28-12-2009, 11:26 AM
  4. timing belt/chain setting
    By CAL-FTW in forum V8 Development and Modification
    Last Post: 04-10-2009, 07:33 PM
  5. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
