Results 1 to 2 of 2
Thread: VN V6 series 1 auto problem
    Holden VN Calais V6
    Feb 2011
    Mildura
    Default VN V6 series 1 auto problem
    hi guys
    ive got a holden vn calais series 1 V6 Auto and the engine light lights up in the dash when driven in 1st and 2nd gear only. engine light will dissapear afer a while or if engine is switched off and switched back on. the speedo and odometer and average fuel mileiage doestn work because of the sensor on the end of the transmission is broken. could this be ralated or do i have a different problem??
    Thanks
    91 vn s
    Jun 2009
    Adelaide, SA
    could be.. Search the thread "check VN computer fault codes" - well soemthing similar to that. Do that procedure and the computer gives you an error code which indicates the problem area
  1. vs series 1 auto ecu/pcm
    By cannibalrikman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2010, 10:42 PM
  2. VN 6 cyl series 1 Auto Transmission Problem, Where to buy a good used tranny?
    By 928S in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-07-2010, 05:40 PM
  3. Vr Series 2 auto
    By kylej in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2010, 06:44 PM
  4. [NSW] auto box for VP series 1
    By notthekingswood in forum Swap / Wanted to Buy / Trade
    Last Post: 15-01-2009, 07:47 AM
  5. series 2 auto to series 1
    By Kruza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2008, 07:40 PM
