Results 1 to 5 of 5
Thread: Is this motor worth the trouble?
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    Default Is this motor worth the trouble?
    Hi Guys
    I've bought a 2nd hand VR motor to go into my VP from a local wrecker. Posted a thread about it a week or so ago. Anyway started tidying up the replacement and took off first rocker cover to find a thick off-white gunk all over the rocker gear and up under the rocker cover. Second rocker cover is the same. Obviously an oil and water mix and it doesn't look healthy at all. What do you think? Is it an obvious sign that the engine is cactus? I certainly don't intend to go to the trouble of installing an engine that is likely to be no good.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    that's rooted. take it back and ask for a good replacement!!
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    adventra
    Feb 2011
    brisbane
    could be as little as a head gasket i spose
    or inlet manifold gasket
    just pull heads off and have a look if you think its rooted then theres nothing to lose
    clean it all down with turps of something empty oil and fill start again
    daniel d
    commodore
    Aug 2009
    australia
    take it back and tell them to swap it over for one without a blown headgasket it possibly could have been cooked aswell as the blown gasket i wouldnt waste my time doing all the work putting a substandard motor in.
    Feb 2011
    nowra, NSW
    Thanks for the responses guys. Yeah, I reckon best case scenario is leaking inlet manifold but could be more serious. Plastic fitting where the by-pass hose goes into the inlet manifold was broken so that makes it more likely that the engine has suffered heat stress. I should have looked at the motor a little more carefully before I bought it. I guess it's going back
  1. Trouble times trying to fit vx motor to vs
    By "Showme" in forum V6 Development And Modification
    Last Post: 17-05-2009, 01:46 PM
  2. Is this amp worth it - or not worth my trouble?
    By NathanJC in forum Car Audio
    Last Post: 18-03-2009, 10:58 PM
  3. Is it worth the trouble
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2006, 10:52 PM
  4. VK V6 conversion is it worth the trouble??
    By palmsvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2005, 10:32 PM
