hey guys got few annoying issues on my vn daily need advice
my exhaust was never vibrating even after i lowered it, but out of nowhere its knocking something and its all hooked in, but seems very close to the floor/hand brake cable
seem to be related to lower the car - maybe a little homework before lowering it may of helped.....
the angle of the drive shaft will be different from lowering it....sometime there is shims under the middle hanger to be taken out when lowering also...
remember for every action there is a opposite reaction !
Exhaust just needs to be bent to compensate for the lowering IMO !
ok fair enough hopefully i can fix these things myself
i used to have a knock in mine at idle, i think it was knocking at where it went over the diff. it could probably have been fixed by a panhard rod to centre the diff better, but the place i took it too ground a bitt off the knocking bit (one of the u clamp bits on the exhaust join)
that fixed it for a while, i think it came back eventually.
