Results 1 to 12 of 12
Thread: Catalitic converter
    Vp series 1
    Jan 2011
    Default Catalitic converter
    How can you tell if your catalitic converter is stuffed, i have exesive fuel consumption, i use 250 kms to a full tank.. If thats not caused by stuffed cat... Wat could be the problem, also ive checked for fuel leaks and cand find any..
    1990 VN Wagon
    Apr 2010
    Sometimes if the CAT is stuffed the car wont go over a certain RPM and struggle to get to 80 ks and the car will run like crap (it happened to my VN and it was cat or tho i am having dramas again and i think it might be a cat problem again :S) but if not it could be a faulty MAP sensor, Oxygen sensor, and possible throttle body. Dude i hope this helps
    Vp series 1
    Jan 2011
    It has alot of power in first then it just drops power when it changes from first then it struggles to keep up after that... The engine is running like shit and is shaking when in gear...
    1990 VN Wagon
    Apr 2010
    Quote Originally Posted by Vp stocko View Post
    Dude, By chance does the car seem like it is sucking to the max through the intake pipe, wants to go but it feels like the hand brake is on from about 60 ks ??
    Vp series 1
    Jan 2011
    Sometimes its like when ur drivin a maual and ur in 3rd instead of second.. And sometimes i put my foot down from take off and it takes a while to pick up power
    1990 VN Wagon
    Apr 2010
    It sounds like you have the same problem as i have .. i get about 280 ks to a tank and its slugish as hell almost as if it was stuck in gear or handbrake is on and not responding as good as it did .. I am changing my convertor 2 morrow and i will let you know what the outcome is mate ..
    Vp series 1
    Jan 2011
    1990 VN Wagon
    Apr 2010
    It would depend on who you go to .. I have had a new one quoted at 350 fitted .. wreckers about 80 - 150 .. But i have one here i took of a wreck that i had that is 2 weeks old ..
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    u want to work your way thru parts one by one starting with most obvious..
    bad fuel consumption and performance... so: injectors, ignition system (coils, spark plugs, leads), sensors (coolant temp, 02 sensor)
    its a long slow process of elimination, but at least in the end you will have new and/or replaced parts
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    if the cat is blocking up the car will start to run hotter than normal specially under high load conditions. check ebay can get hi-flow 2.5 inch or 3 inch cats for 200 to 250.
    VN Calais With All The Factory Fruit I Need!
    Vp series 1
    Jan 2011
    Ive changed spark plugs leads but not coil pack... Ive got a 2 1/2 inch cat back system.. So i mite change coil pack and converter and see how that goes..
    1990 VN Wagon
    Apr 2010
    Ok, i have changed my cat but come to the relisation that it has been punched out or fallen to bits .. Therefor my next thing is to change the rear muffler. I rechecked my crack angel sensor and it actually runs somewhat better .. Still crappy and slugish, But it is better then it was
  1. catalitic converters
    By wookiefunker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2010, 11:45 AM
  2. cat converter on vz
    By Dz811 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-01-2010, 10:30 AM
  3. Best wma-mp3 converter
    By Philthy in forum The LAN Lounge
    Last Post: 13-05-2009, 12:47 PM
  4. Lockup converter / non lockup converter, whats the difference???
    By stealth616 in forum V8 Development and Modification
    Last Post: 07-02-2009, 06:29 PM
