Results 1 to 5 of 5
Thread: Running ruff.
    VN Exec 1990 3800 V6 Man S/W
    Feb 2011
    Molong
    Default Running ruff.
    I have a VN 3800 manual, began running poorly last Sunday, took the fuel filter off, blew it out and was full of rust/brown dirt, changed it, no difference to running, then the in tank fuel pump died, changed it, still running poor, changed starter motor, changed geny, blew out fuel line, still the same running ruff, picks up good on flat or down hill, but as soon as I begin an upward climb the car drops in power like it has dropped half a cylinder.
    Any ideas?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    If there was that much shit in the filter I'd be cleaning the injectors or getting new ones.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    What about the ignition system? Might be a problem with that?
    But definitely throw some injector cleaner or even consider getting the tank flushed and the lines blown...
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Having dropped half a cylinder itll still run good as gold.. Had a really low compression in my old vn and it was perfect.
    Clean your fuel/lines, Check your Injectors, Replace sparkplugs + leads, Clean/replace air filter.
    If none of those help, Do a error check.
    Checking your Computer for Faults (VN - VP)
    if NONE of these help. Take it to mechanics.
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
  1. vs supercharger running real ruff..
    By mz-v6-2c in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2010, 08:34 PM
  2. VN Commodore S suddenly running ruff
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2009, 12:47 PM
  3. vl turbo running ruff
    By vlturbs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-09-2008, 09:28 PM
  4. Are they really so ruff?
    By VL Berlina 5speed in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 08:38 AM
  5. running ruff
    By vpssguy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 03:53 PM
