Results 1 to 9 of 9
Thread: Brake light issues
    vn commodore
    Apr 2010
    Default Brake light issues
    Hey guys im having dramas with my brake lights, when the lights are on drivers side tops real bright and passengers bottom bright. then u push the brake and the top passengers turns off and the drivers side bottom brightens up.
    Its got me stumped i checked the bulb holders one was stuffed to i got a replacement and wired it up but hasn't made a difference im trying to hunt down some decent looms for both sides but any ideas welcome.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    The earth on these looms seems to corrode leading to back-feeding of voltage and bizzarre lighting behaviour and sometimes odd speedo movement.
    You can fix the looms if you are keen and know how to track down the dud connections (caused by corrosion where wire joins metal frame) by testing resistance (continuity) from each pin on the plug to it's end point at the other end of the wire (not just at the end of the wire but at the piece it connects onto) Once you have located the duds mark them then you need to solder the wire onto the metal frame, re-doing the standard connector will not last long. The metal frame will not come out of the plastic holder easily you will need to apply an electric drill to get it out.
    Sorting these looms will fix most lighting issues you will ever have on a VN-VP. It's worth sorting out, once you've done one side the next one will take about 15 minutes.
    With the looms and plugs out you can also see exactly how the single and double filament bulbs go in and which way around the double filament bulb goes
    (hint park light filament is less bright than brake light filament)
    You will need a multimeter or a test light and 12 volt battery charger to find the bad connections. I prefer to use a multimeter.
    Enjoy!
    PS you can buy these looms new from Rare Spares for about $30 each.
    Warranty Void
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    Quote Originally Posted by Warranty Void View Post
    Enjoy!
    Just a question Warranty, what makes you think back feeding is happening on a DC circuit?
    The most I could see occurring is the corroded base for the globes bridging the brake or parker circuit, and one or more globes are feeding from a single or multiple bridged positive? remembering they are all positively switched, and all share a common earth.
    I ask this because back feeding refers to reverse polarity in a circuit (usually from induced current) and I work in the industry.
    So i'm not having a c0ck measuring contest with you, i'm asking where your coming from because maybe there is something i've missed or haven't thought of....
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I've seen blown bulbs cause this though it usually earth related
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vn commodore
    Apr 2010
    wow thats alot to take in lol i have swaped bulbs round and had same results 2 new bulbs in atm i have noticed that a couple holders are corroded mite try get new looms and see if that fixes it just got wof due in a couple weeks so wanna get it sorted.
    vs commodore
    Oct 2009
    Tamworth NSW
    Its a long shot,but if you cant find any other cause,then check the wiring connector for the main rear tail light loom,which is located in the boot on the right side.Ive seen these connector pins corrode on earlier model commodores and cause problems similar to yours.We just unplugged the connector and cleaned up the contacts inside it and it was fixed.
    VP Berlina LX V8
    Sep 2009
    Cheers Coast Calais,
    Might be just a technical term that I have misused, but that is how I think of the behavior of the current when the earth to the correct bulb or filament is absent and the result is another bulb or filament lighting up due to shared earths. I agree it shouldn't happen on positively switched DC circuits but I can't think of a more appropriate term for what appears to be happening.
    Warranty Void
    vn commodore
    Apr 2010
    hey guys i swap the loom and get all the lights goin when the head lights on but now i have no brake lights at all even the highstop isnt working this is really ####in me off and im running outa ideas
    VP Executive
    Jun 2008
    Had a similar issue with my VP due to badly corroded bulb holders and was told by wreckers second hand ones will do the same thing. It is an earth issue due to the high current draw for the stop lights. The bad earth causes the current not to be able to pass thru. I cleaned each bulb holder and filed a clean contact area and then soldered the earth connection to each one and then ensured every bulb holder had a good solid earth connection and the lights are as good as the day the were installed. Took a little while to clean and resolder but for the past 3 years have not had aproblem with the rear tail/ brake , indicator or reverse lights.Tom
  1. VS Calais cruise/brake light issues
    By nathanVY in forum Electrical Wiring / Questions
    Last Post: 16-03-2012, 06:51 PM
  2. HELP!!!!!!!!!!!!! brake light issues
    By grn super low exec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2010, 11:58 AM
  3. Brake Light Switch Issues
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2009, 05:38 PM
  4. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  5. HELP PLEASE: VT Brake Conversion Issues...
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2006, 06:19 PM
