Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By hi_ryder
Thread: vn instrument cluster
    vn executive
    Mar 2011
    perth
    Default vn instrument cluster
    Hey all,
    I recently bought a level 2 instrument cluster from the wreckers and fit it into my vn. All the gauges work fine but im just wondering if the tacho could be reading incorrectly as when i put my foot down its changing from 1st gear to second at ~4500 rpm? im not sure if the cluster is from a v8 is there any way to tell? and is it unusual to get those reading?
    Cheers for any help
    Matt
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The V8 cluster will have green on the tip of temp gauge threads. The tacho will be stamped with V8 on it if you pull the cluster apart.
    and 3 Dangerous non ABS VN's
    vn executive
    Mar 2011
    perth
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by vncommo93 View Post
    Cheers for the help. What you mean at the tip?
    Thanks
    On the back side of the cluster where the thread for the temp gauge is (has 2 brass nuts holding it in place) - the tip of the thread is painted green.
    vn executive
    Mar 2011
    perth
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Its probably changing that early because the kickdown cable is a bit loose.. you can tighten it up on the throttle body by pushing the greyish button and pulling it 1 or 2 clicks to the right. best off to read this though
    vn kickdown cable....
    Best to not mess with it if you're not 100% sure but
    vn executive
    Mar 2011
    perth
    thanks mate,
    it seems to still be running fast in the drags like beating ve sv6's and stuff. the car is completely stock. would it make any difference if i tightened it to rev higher? also could it just be a shotty tacho?
    cheers
    88GreenVN's Avatar
    Jun 2006
    The VN tacho is know to be lazy at the best of times. Run a VR/VS tacho in it and it will be heaps smoother.
    vn executive
    Mar 2011
    perth
    dosn't the vs/vr instrument cluster when put in the vn smoke/catch on fire?
    VL Commodore
    Aug 2011
    Melbourne, VIC
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    think he ment the actual tacho piece removed from the cluster unit and transplanted into your old one. there all the same and just have different needles and face plates (that you can also change)...
    dont sweat the petty... pet the sweaty...
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    so did i a while ago damm things.
    Originally Posted by 87RB30VL
    Huh? I got given the gun of my neighbour,
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Instrument Cluster
    By binghy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-06-2009, 09:47 PM
  3. VC SLE instrument cluster into VC L
    By jakbob in forum Electrical Wiring / Questions
    Last Post: 01-03-2009, 09:24 PM
  4. HSV instrument cluster
    By PhantomSV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-09-2008, 07:18 PM
  5. Instrument Cluster
    By VX_S_S/C_V6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2006, 07:48 PM
