Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By bj42turbo
Thread: Wheel bearing/Rear bushes.. How to tell if they're buggered??
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Default Wheel bearing/Rear bushes.. How to tell if they're buggered??
    Hey guys just as of recently my cars been making a lurching noise as i take off quickly from a stop... the noise is worse when im turning left and taking off..
    It sounds like its coming from the left hand rear of the ca. i havent had a chance to look at it properly but if anyone can tell me how i can tell which one it could be, what to look for and if anyones had similar issues.. opinions or anything.
    1990 VN Wagon
    Apr 2010
    wheel bearings are easirr to know if they are buggered. If the wheel bearings are buggered either side, It will sound like road noise. If its your left hand side, When you turn right it will become more aggressive and visa versa for turning Left, the right hand side will become more aggeressive. Now if it is your left hand side that is U/S, turning left will actually make it quiter then normal. Does this sound like what is happening ???
    If it was bushes:
    Lower and upper control arm bushes U/S-- Slight swaying in the rear and Possible knocking and excessive tyre wear. Also when u take off hard, the car will crab walk to the left !! Both my VN wagon and NF fairlane did the exact same thing. Taking off was worse, Id take off hard, and it sounded like the Lower cont arms, where trying to punch there way into the floor :S
    Sway bar link pin and D bushes -- Slight knocking and swaying of the rear. (knocking = Thumping and/or tinging sound)
    I would honestly get under the rear of the car first and see what which rubbers are cracked or cracking .. Hope this helps mate
    Quote Originally Posted by Zarconia View Post
    Looks like most of the women here in rocky. Hot from the back and ugly as sin at the front
    May 2010
    Croydon, Vic
    May 2010
    Croydon, Vic
    Still have the wheel bearing issue.. had the bushes checked n replaced, it actually gets worse when i turn left and is on the left hand side.
    I had the wheel off n was able to move the hub slighlty.. this would indicate the wheel bearing??
    VQ Stato & Evo VII.
    May 2006
    Melbourne, North of.
    With the wheel on, grab it at the top and bottom of the tyre and try and wobble the wheel inwards/outwards. If there is movement when doing this, then yes, the wheel bearing has done its dash.
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by WNTDVT View Post
    funny I jsut saw this thread,my missus was complaining that there was a noise coming from the front left wheel on her Jackaroo..
    I think this was the problem, can you guess which is the new wheel bearing.
    Dazz
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
  1. ve rear wheel bearing
    By damirdagsy in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-07-2011, 08:30 PM
  2. VQ statesman rear wheel bearing
    By clubsport_replica in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2009, 06:59 PM
  3. could it be the rear wheel bearing?
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2009, 12:09 AM
  4. Rear Left wheel bearing gone
    By darekg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2009, 07:21 PM
  5. GM - 92077119 Rear Wheel Hub bearing
    By jazza15 in forum General
    Last Post: 19-08-2008, 08:48 PM
