Results 1 to 4 of 4
Thread: V6 wont start.. Help?
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Default V6 wont start.. Help?
    Ok so here is the story, had a leaky sump so I ripped out the whole suspension and k frame so I didnt have to take the engine out. because I couldnt be bothered with all the wiring..
    All done and back together, car cranks but wont actually start.
    - It has fuel getting to the injector rails, and injectors are pulsing. Also have gas so it should work on gas even if petrol doesnt.
    -Battery is fine and cranking pretty hard.
    -Has spark so it doesn't seem like a CAS
    -All earths and sensors are connected.
    -Tried another ECU just incase and checked to make sure no fuses are blown (all fine)
    Also when I done the sump I redone my timing to -2 instead of 0 (have a JP chain set) but I dont think 2 degree's would cause a car to not start, Also changed the knock sensor and oil pressure sensor and soldered on new clips for them...
    knock sensor is 1 wire, and oil press is 3 coloured wires so practically impossible to stuff it up....
    Anyone else have any idea's on what could be the problem? im stumped... Any help would be greatly appreciated
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Just an update, changed leads and plugs just in case and is still doing the same thing....
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Yep, all correct, I wish it was that lol
  1. VT 5lt wont start please help
    By R8THIS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2010, 06:17 PM
  2. VR V8 wont start when hot...??
    By bandit10 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2010, 10:04 AM
  3. VL wont start
    By vlcalais11 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-02-2009, 09:54 AM
  4. VR wont start
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 12:35 PM
  5. vl wont start
    By NVE_069 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-09-2005, 05:00 PM
