Results 1 to 8 of 8
Thread: Clogged lifters
    Vp series 1
    Jan 2011
    Default Clogged lifters
    If my valve lifters were clogged with sludge could thiscause valve problems / low compression in the cylinder?
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    If the lifter is ''Pumped up'' and wont release then yes the valve will be open all the time.
    If it was completely off the seat then you probably would even get a reading on the gauge.
    If the valve is only just touching the seat then it would register low compression.
    But if the lifter is that pumped then the engine would be missing and making a tapping sound like the rocker arm is hitting the rocker cover.
    Vp series 1
    Jan 2011
    3.8 VS Ute
    Jun 2010
    its worth a try. i had some intermittant rattles and ticks coming from my lifters. i used the famed "snake oil" (engine oil flush) which supprisingly worked a treat. flushed it then added some lifter free additive with fresh oil. seemed to stop the problem straight away. if your not keen on the oil flush additives there is a product called Auto RX i think. a little harder to come by but i think you can order it from the states. it apparently works a lot slower so not to cause damage to your seals ect. your other option is using a high detergent desiel oil. we have a few trucks and tractors and on occasion about 500 km before i next service i dump the oil, fill up with Devlac and then after 500km dump that and change the filter. i'd say if they are making a lot of noise or you think they might be really clogged you may have to pull them out and service them. its worth a trying the other things first as they are a lot cheaper/easier than stripping down you engine. just a few suggestions, as usual i take no responsibility for any problems or damage you may cause if trying any of these methods rah rah rah.... hope it helps. there are probably some other people on this site which would have a much better understanding then me. good luck
    Sep 2005
    Use engine flush. Let it idle for 20 mins.
    Dump the oil.
    New oil and filter.
    Add nulon lifter free. Leave it in till next oil change.
    If that doesnt work then change the lifters.
    Vp series 1
    Jan 2011
    Vp series 1
    Jan 2011
    My engine is only runing on 5 cylinders, Did a compression check on the cylinder that is missing and it had 30psi... Hopefully its something like a sticky lifter ( it makes a tiking noise under tapet cover) and not a burnt valve..
    Sep 2005
    Quote Originally Posted by Vp stocko View Post
    Will it help if i bought oil additives to unclogged them
    Thats what i said in the above post.
  1. symptoms of a clogged fuel filter but isnt..
    By veeteeesscom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2010, 01:24 AM
  2. [Ecotec] Lifters Help please.
    By acarmody in forum V6 Development And Modification
    Last Post: 03-03-2010, 09:39 AM
  3. lifters on vx ss
    By GM GEN3 in forum Yella Terra
    Last Post: 28-01-2010, 09:16 AM
  4. Lifters, where are they?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2006, 04:37 PM
  5. Lifters...
    By seventh path in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2004, 10:44 PM
