Results 1 to 3 of 3
Thread: Vp fuel tank thoughts...
    VP commodore
    Dec 2010
    Queensland
    Default Vp fuel tank thoughts...
    So i have a quick question...
    As i learnt the other day my 92 VP has a return line entering the tank VIA my sender unit...
    BUT my mum has a 92 VP that has her return line entering directly into her tank... Was there a change in tanks in the two month difference is it a possible that mine or her tank has been changed?
    Classic, Not Plastic <3
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    I think the change occurred with the VR, so your car has a VR tank. Not unusual for the end of model runs to be fitted with the next model parts (if they fit that is)
    (Is your VP a later serial number than your mums, maybe close to the end of the run serial number?)
    Illegitimi Non Carborundum
    vs commodore
    Oct 2009
    Tamworth NSW
    This change occured on the later VP models made on or after the 26th October 1992.There were a few changes made.The fuel tank return line was moved to the sender unit ,instead of being a seperate connector on the fuel tank.The rockers in the V6 engine were changed,the CAS (Crank Angle Sensor) is non adjustable.There was a revised fuel pressure regulator fitted with a larger diameter vacuum hose.There was revised injectors fitted.There was a revised memcal fitted, and error code 35 will now set if the idle cannot be controlled by the ECU through the IAC (Idle Air Control) solenoid.The heavy duty brake package that was available as an option on early VP's is now fitted standard to the later VP's.Theres a few other changes made,I think ABS was introduced,and there was a few smaller changes that I cant remember.
  1. 1998 vs statesman v6, 80l Fuel Tank into VN V6 with standard tank
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2011, 07:30 PM
  2. Ezi fuel injection...thoughts on this?
    By Stretchomatic in forum General
    Last Post: 03-08-2010, 05:21 PM
  3. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  4. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  5. Thoughts about vr fuel pump tip
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2005, 07:23 PM
