Results 1 to 11 of 11
Thread: Vs 5 spd
    VT SS 5.7
    Mar 2005
    Goulburn
    Default Vs 5 spd
    Hi guys will a vs v6 5spd fit into my series 2 vn v6?if anything needs to be change could u list it please thank you
    Real cars don't power the front wheels, they lift them
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    If its a borg warner t5 yes
    If its a getrag? then no.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    VT SS 5.7
    Mar 2005
    Goulburn
    The diffrence between the t5 and getrag is where the Reverse gear is located isnt it?
    T5 off memory is right and down and getrag left and up ?
    some_guy's Avatar
    VR SII Exec.
    Apr 2009
    brisvagus
    No thats not the difference. Your thinking T56.
    T5 5 speed = cable clutch
    Getrag 5 speed = hydraulic clutch
    T56 6 speed = hydraulic clutch with reverse to the left and up.
    97 WRX AWD
    VT SS 5.7
    Mar 2005
    Goulburn
    Now im with ya, i would also have to find a vn manual computer too since the vn is an auto atm
    some_guy's Avatar
    VR SII Exec.
    Apr 2009
    brisvagus
    You can get your memcal retuned to use as a manual, talk to doctor bob and delcowizard about it.
    You can buy a kit for vr's on ebay, trx100 ebay shop lnk check with him if there is one available for a vn.
    97 WRX AWD
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by madsav View Post
    VN manual/auto run the same computer and will both run the on the same tune. You also can fit a getrag box but it requires a little more, you would need a hydrolic pedal box, possible different bellhousing? Im not sure but it can be done if you really want to but in IMO T5 is a better box anyway.
    The complete Vn-Vr Manual Conversion Guide.
    Lots of info in that thread. What parts have you got? Or is the box all you have?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Yea around these parts people opt for the T5 over the getrag. Some wreckers i know wont even do a getrag conversion cause of the issues they have.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Why not do an ecotec conversion at the same time?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    vn 5ltr execitive
    Feb 2011
    beenleigh
    as for the auto and manual computers all thats is manly difrent is the idel speeds are dif an othe good option u can do is use a v8 computer with v6 memcal it makes the rev a lot better try it and u will see
    looking for out side sun visor for vn
    VT SS 5.7
    Mar 2005
    Goulburn
    Can pick up a whole vs commodore with around 230,000k`s wont have any need for anything but the whole manual conversion the guy wants $500 ,only because it has front end damage
