Results 1 to 8 of 8
Thread: MSD ignition setup HELP!
    VN SS
    Mar 2011
    Auckland, NZ
    Question MSD ignition setup HELP!
    Hi all,
    This is my first post in any forum on the internet so bear with me... I have tried to search the forum for information but I can't seem to find anyone with the same issue.
    I have purchased a MSD 6AL & Blaster SS coil to replace the stock units. I have wired following the MSD guide cross referenced with the stock wiring diagram & ECU pinout.
    When I try to start the car I have a go/no go situation. During crank the engine will try to fire & will run for maybe a second or two then die. The coil and MSD are firing as there is spark at the plugs fuel flow seems ok... What now?
    Thanks in advance for any help
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    welcome to JC
    ok, how many wires do you have on the coil? there should only be 2, the ones coming from the MSD unit.
    you should have the trigger wire from the MSD unit (white wire) connected to the ignition module (brown wire i think), the +12volts ignition wire which was connected to the coil/ignition module (red wire) should be wired to the MSD unit for the switched 12v signal.
    can't think of anything else right now. if that doesn't help i'll have to find my manual
    magnetic pick-up wires aren't used (green/voilet)
    Body by Holden, Soul by Brock
    the Legend will live forever
    VN SS
    Mar 2011
    Auckland, NZ
    Thanks immortality,
    I have got only the orange & black running to the coil from the MSD, however I was trying to use the light blue/white as the trigger signal off the dizzy. I'll try tapping the white trigger into the brown (original coil -). I'll definately be checking in once I have sorted to let you know how I get on.
    VN SS
    Mar 2011
    Auckland, NZ
    Ok, no luck... in fact I lost all spark changing over to the brown wire. I will try to explain as simply as possible what I've wired to where and see if there is any further help that is out there.
    MSD - Factory harness;
    Heavy Red - Bat (+)
    Heavy Black - Engine ground
    Mag pickup - not used
    Tach output - brown (does display reading on tach)
    Orange - Coil (+)
    Black - Coil (-)
    Red - Pink (switched 12v - ex-coil (+)) & White/Black (dizzy (+)
    White - White (EST output from ECU) & White/Violet (dizzy reference input signal ECU) & Light Blue/White (Dizzy signal)
    Factory Loom;
    Grey/Red (dizzy (-) - Black (ground)
    I think that covers it. My only thought from here was to try installing the MSD dizzy PN 85891 (ready to run) to allow for mechanical timing adjustment rather than ECU controled. Any further thoughts?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    all you do is leave everything stock apart from the coil wiring and setup 6AL in the instructions for points trigger mode with the old coil negative triggering the msd box
    Apr 2006
    Auckland NZ
    you shouldn't have anything connected to the dizzy
    you just want to use the 2 wires that came off the coil. +12v (red) from the coil to the switched +12v wire (red) for the MSD, brown (-ve) wire from the coil to the white trigger wire on the MSD unit.
    i wonder if it's done any damage trying to connect to the dizzy?
    if the MSD is wired up correctly, if you take the white trigger wire and earth it and then lift it off the earth connection it should create a spark (would need to have the ignition switched on)
    where have you got the tacho output connected to?
    VN SS
    Mar 2011
    Auckland, NZ
    OK thanks guys, I have found the errors I made and I'm rectifiing now, however I think I may hav damaged the dizzy as after completing some checks I seem to have no signal and got an error code 41 'cankshaft sensor' so I'll keep you posted once I get it running again.
    VN SS
    Mar 2011
    Auckland, NZ
    Thanks for your help here guys, I have got the VN fired up and running again thanks to your input on finding my wiring issue. Cheers
  1. No Ignition Spark from ignition coil?????
    By Huddo001 in forum V8 Development and Modification
    Last Post: 14-04-2010, 06:54 AM
  2. ignition setup 304ci
    By silver88vl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2009, 03:24 PM
  3. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  4. VS sub setup
    By carlntez in forum Electrical Wiring / Questions
    Last Post: 14-09-2007, 01:40 PM
  5. VK Stock drum and disk setup to a VT disk setup
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 09:37 PM
Tags for this Thread
