Results 1 to 11 of 11
Thread: VN stalls/wont start when warm
    VR Exec II
    Sep 2007
    Exclamation VN stalls/wont start when warm
    Hey everyone
    A few weeks ago the fuel pump went in my vn sedan so i replaced it with a brand new one. Since then my car hasnt been running right, she starts firt time and runs ok but when u shut it off and go to start her again it just winds over without firing. If i let the car sit for a couple of hours and cool rigght down it will start. The car will also stall and roll to a stop aftrr 5 mins or so of driving. I have been told it could be the crank angle sensor? Also the temp guage on my vn must be dodgy because it barely moves, car will idle for half hour before the needle even gets to quatr and the engine seems alot hotter then the guage reads i cant rest my hand on the top of the intake manifold. Could my car b over heating and stallin without me knowing it?any advice is apreciated thanxs.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Change the CAS first and see if that fixed the stalling. It's the most probable cause of stalling and not starting when hot. To test it you can poor cold water over it (CAS) when it next stalls and fails to start. By cooling it down it may fire up then.
    and 3 Dangerous non ABS VN's
    2002 S2 VX CLUBSPORT
    Mar 2011
    Melbourne, Altona
    Yeah poor a heap of water all over your crank angle sensor sometimes a heavy duty degreaser can clear shit out of it and fix it.... then try and start it... if not bottom half of your coil pack could be F'd ... series 1 or 2 ?
    Only push bike's have 2 peddles !
    VR Exec II
    Sep 2007
    Thanxs for the help. Its a series 1 motor, im going to clean the cas tonight. How much am i looking at for a new cas? If that fails i will replace the coil pack base aswelll.
    Mar 2011
    Melbourne, Altona
    Depends I get trade so not sure on the retail ... I'd expect to pay somewhere around the $50-70 mark.. You'll need a puller to get the balancer off but, so you might want to line one up !
    Coil pack I'd slap a vt top on it probably $50 - $100 depends where you go !
    VR Exec II
    Sep 2007
    Should i replace the top or bottom of the coil pack? The water method works maybe 50% of the time but engine stalls shortly after.
    Mar 2011
    Melbourne, Altona
    I'd be changing out the crank angle sensor before you go any further !
    VR Exec II
    Sep 2007
    I have replaced the cas with a new one. Is it normal for the inside rim of the harmonic balancer to rub on the side of the plastic grooves on the cas?? I havent started it yet because i dot want to damage the cas.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    No, should pass but not touch each other. Is the replacement you have identical to the old one?
    Is the old one adjustable?VN stalls/wont start when warm-latercas.jpgVN stalls/wont start when warm-vn-cas.jpg
    Illegitimi Non Carborundum
    VR Exec II
    Sep 2007
    Yea unfortunatly they have given me the all plastic one when i need the one with the metal bracket, i asked for a series 1 and they assured me it was the right one grr.
    VR Exec II
    Sep 2007
    Got the correct CAS from my local mechanic. Put it on today and aligned it properly, now my car starts first go every time =D auto pro would not refund the other CAS because it was damaged by the balancer even though they gave me the wrong part to begin with ,bit dodgy but eh i shoulda checked it first. Thanxs for all the help.
  1. Vp nearly stalls when warm
    By Auzzie_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2009, 06:03 PM
  2. warm start trouble
    By reardo_202 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2007, 02:14 PM
  3. VH commodore stalls when warm
    By bigfella99 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-11-2006, 09:36 AM
  4. VT does not start when warm
    By RichardW in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2006, 10:00 PM
  5. No Idea, Car wont start unless warm.
    By BR377 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2005, 10:23 AM
