Results 1 to 5 of 5
Thread: Warm air out vents when heater is off
    VP Executive 5L
    Mar 2011
    Default Warm air out vents when heater is off
    So I've had the car 3 days now, nowhere near used to everything.
    What I have noticed is that if the car has been sitting in the sun for a while, when you drive off quite a bit of warm air continues to come out the vents even when the heater is off and only outside air is coming through, i.e. not re-circulating. After a while it cools down a bit presumably because the hot plastic ducting is now cooling down but it never gets down to outside air temp like when you stick your hand out the window. Is this just normal with these cars, or could maybe the heater tap be not fully turning off or some air flap not shutting off fully and letting some of the heater air come through?
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    I replied to a question just like this a few weeks ago. A few other replies too all helpful. Search the similar threads
    cheers
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Yer mine did that all the time and it seems the normal thing, then my heater core started leaking and mine is the hard to get to version so its just bypassed permanently now lol
    GSXR1000
    Apr 2010
    WA
    does it smell damp/musty ??
    if so might be worth looking into heater core.
    Mine's gone on the VT. and unless I run the aircon on cold, it blows hot air.
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    If it's excessively hot, then yes check heater core and engine bay tap for correct operation.
    However, by what you have said it's completely normal for the air to not be the same temp as hand out the window. It's residual heat in the dash, and the fact the fresh air is coming over a very hot bonnet on a warm day, before it circulates through your still warm dash...
  1. VN Heater/Vents not hot
    By Pickled in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2010, 10:48 AM
  2. warm air coming out of vents even when turned off?
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 02:56 PM
  3. warm air coming out of vents even when turned off?
    Last Post: 23-05-2009, 02:28 PM
  4. Heater blows luke warm air help
    By viper05 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-07-2008, 01:01 PM
  5. front air/heater vents
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2006, 03:03 PM
