Results 1 to 4 of 4
Thread: Lights on my commy vp keep dimming
    vp commodore
    Mar 2011
    lockhart
    Unhappy Lights on my commy vp keep dimming
    I have a vp commodore. I replaced the engine with a vr motor was good for a while now lights keep dimming and battery light stays on. I checked for loose earth wire but all good any suggestions?
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Quote Originally Posted by commyvp View Post
    Battery is the issue perhaps....?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Check/replace the voltage regulator in your alternator. The brushes may be worn. Looks something like a dunny brush.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Voltage regulator in the alternator is most likely culprit, it will come off with two screws undone, dont try and force it straight out, you have to take it out on an angle or you'll break the carbon brushes. same goes for replacement. If youy are handy or know someone handy you can do the job cheap by replacing the carbon brushes only. If you replace the assembly you are looking at $60 or so for the part.
    Warranty Void
  1. Dimming Dash on Executive
    By maccasparks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-10-2010, 02:11 PM
  2. dimming instrument panel on VE
    By just new to VE UTE in forum VE - WM
    Last Post: 10-05-2009, 12:24 PM
  3. Dimming Lights
    By whitevrboi in forum Car Audio
    Last Post: 20-06-2008, 08:01 PM
  4. lights dimming?????
    By lilkel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2006, 08:41 PM
  5. Headlights dimming
    By sikvs in forum Electrical Wiring / Questions
    Last Post: 26-05-2005, 06:52 PM
