Results 1 to 7 of 7
Thread: Inlet manifold gasket
    LX SL/R torana, HZ SANDMAN, VH SL/E top 30
    Apr 2009
    BALLARAT
    Default Inlet manifold gasket
    Hi all. My vn era 304 has been running really rough. Coughs and farts and feels like its not running on all cylinders... All plugs and injectors are ok. Compression is ok too. I had a mate spray some cfc near the manifold which he said got sucked in and made it run worse. He reckons now that its got a leak in the manifold inlet gaskets.... Does this sound about right?
    VK sedan
    Mar 2011
    townsville
    vn 5ltr execitive
    Feb 2011
    beenleigh
    as above said but when u do the gasket make sure u retighten it week later
    looking for out side sun visor for vn
    Apr 2009
    BALLARAT
    Thanks guys. I didnt realise a leaky gasket there could make the car run so crappily. I had a read through a lot of posts about it and reckon ill attack it in the next couple of weeks. So just to double check..
    Allow time...
    Drain all coolant first.
    Change coolant and water after..
    Retighten a week later...
    Dont go for cork gaskets...
    Use the proper gasket sealing stuff.
    Place silicon around water jacket areas etc..
    Qs..
    Are the aluminium or plastic gaskets better?
    Do I need to get a torque wrench to do the job properly?
    While Im there is there other stuff I should do?
    Do you need sealant on both sides of the gasket or just one?
    Cheers.
    VB SL/E
    Dec 2008
    Quote Originally Posted by hainzy View Post
    Qs..
    Cheers.
    I try use ACL gaskets where i can.
    IMO you should use a torque wrench on every nut and bolt.
    FWIW there are so many other things to do and check, it seems you would be better off spending the $20 or $30 or borrowing the correct service manual for your car, everything is explained there for you.
    Best money ever spent is on the service manual for your car.
    Apr 2009
    BALLARAT
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Done my inlet manifold gasket a month back, IMO retighten all the bolts the next day, assuming the engine has gotten hot and has gone cold again it should be fine,
    Also do your bolts up in a pattern working from the middle to the outside as it will help to position the new gasket properly.
    I have no real mechanical experience and i was able to do this job with little help, didnt need a torque wrench really but might help.
    Just make sure you take the time to clean all the surfaces, i think i spent about two hours cleaning all up.
  1. Inlet Manifold (Gasket???)
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2012, 02:44 PM
  2. is this a shot inlet manifold gasket?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2011, 09:36 PM
  3. Head Gasket? Inlet Manifold Gasket ? which one ?
    By Hydrobollox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 08:11 PM
  4. inlet manifold gasket
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 11:33 PM
  5. Inlet manifold gasket
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2008, 07:02 PM
