Results 1 to 4 of 4
Thread: Removal of main engine loom
    VP Berlina S2
    Oct 2009
    Default Removal of main engine loom
    Hi everyone,
    Currently removing bits from my VP, prepping for a 304 conversion.
    I've hit a bit of a snag though; how does one remove the main engine loom from the firewall on the passenger side? I am assuming I may need to remove parts of the sound proofing inside the cabin area but once I'm there what do I do?
    Any help will be greatly appreciated!
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    on the inside there should be to big plastic clip looking things, I uses a screw driver to push them in an then pushed the big grommet out towards the engine bay,, i cant seem to find a good pic of it,
    Take out the glove box an side kick panel, follow the wires to were they go through the firewall,, you should be able to work it out from there
    Signature Goes Here
    VP Berlina S2
    Oct 2009
    Hey! Thanks for the reply mate. I was able to get the plug out!
    Now all I need to do is degass the ac, unbolt the exhaust, remove the drive train, and then the coolant lines for the heater, oh and the fuel line, and then finally unbolt the mounts from the trans and engine.
    So much work >.< what have I gotten myself into?!
    Nimbus 2000
    Sep 2008
    Hogwarts
    mate i know exactly how you feel,, i did an engine swap on my own not long ago.
    it was one hell of a job, but never regret doing it, was an awesome learning experience.
    Signature Goes Here
  1. vr dash loom removal
    By python_hunter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2010, 08:10 PM
  2. Interior and main wiring removal
    By tezza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2010, 07:38 AM
  3. VS Main Power Window Loom
    By LittleAlex in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2010, 11:50 PM
  4. Will i Need The Main Wiring Loom that plugs ito the BCM??
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2009, 08:06 PM
  5. Dash loom and engine loom
    By stockies in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-06-2008, 04:44 PM
