Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By budwizer
Thread: Project VH
    weston is offline Holden VH V6 Commodore
    VH Commodore
    Apr 2009
    Default Project VH
    Hey guys would any one know about these two plugs?
    the nine pin/wire plug up the back above the computer with the blue wire this one is on the engine loom and this plug belowthat comes from the dash harness.
    I have a VH commodore and im putting a series one VN V6 into her, i have replaced the whole VH loom with the VN's loom and i have gotten to the stage where i want to start her up but i get nothing better than the engine cranking over and over.
    I have checked the fuel pump and dont seem to find any power at the pump with the test light nor if i pull the hose that supplys the motor then crank i get nothing out of the tank. I have read in another forum that i think its these two need to be joined to get the motor to fire any one with any ideas cheers
    VC
    Oct 2008
    They plug together from what I can make of it, assuming it is the same as a VC. I assume you have the extra harness that splices into the original VH harness?
    VH Commodore
    Apr 2009
    Default Project vh
    No i dont have any of the vh loom left , the only bit is a few inches from the heater controls thats it the rest is all VN but i think your right in that they join
    Vn
    Nov 2006
    Glen Iris, Vic
    hey man the smaller of the two plugs is the diagnostic link plug for the ecu, so you won't need to connect it to anything.
    the bigger one is what connects to the upper dash loom.
    Brown/yellow wire goes to the speedo
    grey/red goes to the auto
    grey is the inhibitor switch on the shifter assembly
    pink black #1 power for theft switch option
    pink black #2 power to the diagnostic switch
    brown white #1
    brown white #2
    light blue goes to the auto
    yellow black goes to the trip computer for level 3 clusters (which i don't think u have)
    ill get back to you about the 2 brown white wires, above was from memory. (pretty sure one of the is engine warning lamp.. ?)
    you will have to connect the following wires
    blue (if auto)
    grey/red (if auto)
    grey to earth (or to shifter if auto)
    pink/black both to +12v
    brown/yellow from speedo (don't need it to start it.. but will need it if u want it to run correctly when driving)
  1. Replies: 27
    Last Post: 21-06-2011, 08:31 PM
  2. VR Project
    By impulsive in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2010, 08:48 PM
  3. My Project Vu SS Ute
    By Robbo47 in forum VT - VX - VU - WH - V2
    Last Post: 01-03-2010, 09:49 PM
  4. My VH Project
    By RibSmasherAu in forum VB - VC - VH - VK
    Last Post: 14-08-2009, 11:13 PM
  5. My New Project
    By HsvPlayBoy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-08-2006, 05:40 PM
