Results 1 to 4 of 4
Thread: How to remove the genie extractor on driver side?
    VT Commodore
    Jun 2010
    Default How to remove the genie extractor on driver side?
    hi i want to clean the extractor while i am replace the gasket
    i have already unbolt the extractor from both side but cant slide it out
    which is different from what exhaust people said
    do i have to remove the 2 bolts on steering colunm and slide steering column backward to get the extractor out?
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    you should be abel to remove the tube that gose around the steering colunm then you can get the lot out .
    vt s pack manual
    May 2009
    gawler, adelaide
    nahh its not that easy, you do have to drop the steering rack out man ive had to do it a few times. just undo it from the K frame and let it hang while you pull them out, make sure they are un bolted from the Y pipe aswell.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As above, undo the two bolts that hold the rack in, and undo the coupling on the steering shaft, then pull the rack backwards off the K frame and push it as far as you can to the right. The extractor comes out from the bottom.
    Visit my Facebook page
  1. Driver side speakers..
    By DarkEnvy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2010, 12:54 PM
  2. How to remove driver side button for side mirrors?
    By SupremeVT98 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-07-2009, 09:14 PM
  3. VT Driver Side Mirror
    By harveyt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2007, 10:13 AM
  4. GENIE Extractor?
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2005, 08:01 PM
