Results 1 to 3 of 3
Thread: Tightening up a LSD
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    Default Tightening up a LSD
    My LSD isn't as tight as it used to be (bit like the misses). Have heard there is a process involved in tightening it back to it's former glory. I have never worked inside a diff, but am handy with a spanner. Is it something to tackle or best left to the pros?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Not something you can really do yourself best left to the pros. what you can do yourself is remove the center and take it down get it tightened and reinstall save you a bit of cash.
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Can i make a suggestion.... Asuming your car is only used for daily duties with the occasional spirited drive?
    Since you will be having the diff center out. I think you should throw a few extra pennies at it and get some NEW oversized clutch cones fitted, rather than just having it 'tightened' AKA shimmed.
    Several times i have thrown money at getting LSD's shimmed and they didnt last very long, most of the time cause the clutch material softens with age. My last lsd lived for 2000 kms and one straightline skid.
    That shimming job cost me $350 all done. then i had to pull the center out again to see that it had bottomed out again. Bit the bullet and put in 2 new oversize clutches ($90 for the pair) and now its good as gold
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. tightening sequence on vr
    By brian101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2010, 02:11 PM
  2. Tightening a Sunvisor
    By seraphic06 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2008, 09:30 PM
  3. Tightening Fan Belt VS V6
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2008, 06:41 PM
  4. Tightening seatbelts?
    By Dougeh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 12:19 AM
  5. Tightening Accelerator Cable
    By Simdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 06:15 AM
