Hey guys im looking for any kind of help i can get with this.
Recently i bent the chassis in my series 1 Vn commodore executive.
It has a decent auto, motor and tailshaft, diff etc..
The car is not fixable or safe to drive.
I have pickd up a series 2 Vn Calais needing a geabox n tailshaft.
I am still learning about cars but i am pretty good at most things i have attemped ex.. brakes, rotors, axles, steering rack, exhaust, controll arms, bushes and more..
I am looking for any help or guides on changing over the transmission (auto) from the executive to the calais. i have trolley jacks and car stands. also enough tools..
If anyone can help me it would be geat;y appreciated. also if theres anything i need to know about the tailshaft.
Thanks alot in advance.
Paul![]()
if you want something for reference along the way, I highly recommend a gregories manual or similar. It really pays off, and is a great guide.
And a trans service kit (gaskets filter oil ect) while you're at it, and probably replace universals and center bearing on tail shaft while you're there...
Otherwise, my experience provided no major secrets, just have beer, a radio, loads of carby cleaner and some mates nearby...
Thanks mate ill have to invest in a manual. Yeh i have 1 mate whos willing to help me, is the carby cleaner just to help undo the bolts? also is the tailshaft fairly easy? cheers bud.
youll be able to use your auto and tailshaft from original car pretty much just a simple swap over job.
Remove tailshaft 4 bolts at diff plus centre bearing mount. Slides out fo gearbox (careful fluid coming out.
Unbolt 6 or so bolts holding gearbox in. remove wiring plugs kickdown cable and unbolt trans fluid lines.
Then install is similar making sure you take note of slots on torque convertor line up with pump
Originally Posted by Smidy
thats when you pull the tailshaft out fluid will come out i find plastic bag and duct tape works well if your quick
Thanks guys i understand now. Is there much to know when bleeding the lines?
not really needed gearbox has a breather at top where itll push out any excess air build up
the hardest part will be unbolting the gearbox from the engine. Most VN's have this heavy cast bell housing cover/brace and you need to remove this to disconnect the torque converter from the flex plate (I would try to pull the torque converter out with the gearbox). To get the cast bell housing cover/brace off your going to have to take off the engine pipes between the manifolds and the cat, unbolt the steering rack from the cross member and the steering shaft and pull it back and youer going to also need to remove the starter motor (make sure you disconnect the battery first or there will be sparks).
Depending on how sagged your engien mounts are you may have to jack up the engine to get the bell housing cover/brace out between the sump and cross member.
It will also be easier to turn the engine to remove the torque converter to flex plate bolts if you take out the spark plugs.
as for dropping the gearbox get a trolley jack adaper so it doesn't fall off or rig up a tie down strap and a bit of flat steel on your jack foot.
I'd probably drain the gearbox as when the filler tube falls out it will go all over the place, so drain the box and replace the sump. Undo the shift linkage, speedo wires, tail shaft and support it on a jack and tie it to the jack then remove it's crossmember and lower it down and backwards making sure the torque converter doesn't come off the input shaft. you may want to rig up a device to hold it in place, a bit of metal and a bolt through one of the holes on the front of the bellhousing for example?
